Rough Idle*** Please Help
Old Jul 31, 2009 | 03:53 PM
RevWilliams's Avatar
I had this posted in the wrong thread earlier
Ive researched all the topics in here on this to get were Im at today, but I need to know more please.
Background: 2004 FX4 6" Lift on 33's, Flowmaster, K&N, 89K miles
The Story: Normal drive home last week, came to a stop at a light and the motor just went limp... Idled like a diesel with a bad tune up, check engine light came on, I tapped the gas and it straightend out, ran fine until the next light and same crap idle. Got home and pulled the code. Said P0012. So I replaced the VCT Solenoid on the drivers side, along with cleanng the MAP sensor and a new fuel filter, and did a test drive. Runs like a champ! until it gets to normal temps and when I come to a light it goes into the rough idle mode again and I get the same engine code. So I think maybe the VCT from the drivers side was still good, so I put it in the passenger side, test drive and same story!!
So is my next step the Cam Sensors on the front of the heads?? or do I need to do the Cam Phasers?? Ive read that doing the Cam Phasers at home is a hell of a job or $1200 at a dealer... is that true? Also, could having one new VCT in with an older one cause an issue?? it was on $117 and easy to put in, should I get another?
Any help here would be GREATLY appreciated!!
Jerry
Old Jul 31, 2009 | 04:10 PM
Matts ford's Avatar
may i ask which motor you have? thats a code for the vct system. have you ever had any work done to the engine? what kind of oil do you use? and fiter? has it ever had a dry start issue? or a rattling from inside the timing cover? camshaft timing may be off, may have a problem with the vct solenoid.
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
Old Jul 31, 2009 | 04:29 PM
Its the 5.4 and I just had the oil changed last week to try and help this as well. I used Valvoline Syn/blend and the weight it said on the Oil Fill
The Filter is a Penzoil I believe. Never had work done on it. I've removed and replaced the VCT Solenoids on both side just a few days ago. As for a "Dry Start" issue... It sounds like a diesel for a sec at start up if thats what you mean??
Old Aug 2, 2009 | 01:51 PM
Pennzoil filters are made by Fram - garbage. Put a Motorcraft FL820S on it, Walmart has them cheap.
Old Aug 3, 2009 | 03:43 PM
Ganners's Avatar
Look at this!
https://www.f150online.com/forums/v8...talling-3.html
Should be sticky.
Old Aug 3, 2009 | 04:38 PM
jbrew's Avatar
Originally Posted by Ganners
Yea, it should be, -definitely. ~ Great info!
