V6 to Lighting Motor
heyy guys i have a 2001 XL f150 4.2L. i just got a 2004 lighting motor and tranny. are there any things i should be aware of be4 i start to put it in the truck
You need the Lightning computer to operate the L trany for one.
You'll need the 4r100 tranny wire harness,dash wire harness, cross member for the 4r100 , 4r100 trany dipstick & dipstick tube,motor wire harness.You'll need to have the drive-shaft shortened and the exhaust rerouted to get around the tranny.
Do you have all the parts to go with the motor? Intercooler hoses,pump,heat exchanger,throttle & cruse cables,alternator,L radiator hose?
Here's a list of some stuff you'll need,,,you wont need all of it. Depends on how much you already have.
http://www.madenterprise.com/scparts.htm
Phil
Phil
lol. 9.75 or swap up bigger than that... i finally popped the 8.8 pinion again. check out my gallery for pics of the carnage. 1/4 " spacer on the gear side of the carrier got nailed so hard it shattered
drive shaft would be easier to have shortened, not gonna be expensive.
... only for so long will the 8.8 handle that kind of power unless it gets other help. i think i would know since i ran the 8.8 with a lightning powerplant... and it exploded... i think my comment counts
i never said your comment didn't count, if its properly set up(with a good LSD or locker) the 8.8 can take a lot of abuse. its what ford put in the new GT500 which has a lot more power than a lightning motor. also what what were you doing when it exploded.
It's totally two different situations.
Yes the 8.8 is very strong. But trying to move a 55 or 6000 pound truck is harder on it then trying to move a little car.
Nothing last forever,
I just riped my 9.75 rear-end out of my truck.
Parts will only take so much abuse and like I said before.(if you aren't breaking something.Your not making enough power or driving it like a little old lady)
Now with that being said. If it was me,,I would rock the 8.8 with the Lightning motor until I ripped it out.
Then I would upgrade to a 9.75
Depending on what you do with the truck and how hard on it you are. That 8.8 could last for some time!
Phil
