could use some HELP please !!!
Old Jul 4, 2009 | 07:34 PM
jjollysc31's Avatar
01 4.6 was running rough so i decided to change the plugs as well as cleaning the entire throttle body (plugs were shot and throttle body EGR ports completely clogged) after reassembly (and confirming many times all connections) the the engine immediately rev. limits when i crank it and stays there. help please !
Old Jul 4, 2009 | 08:11 PM
jbrew's Avatar
I don't understand. - English please.
Old Jul 4, 2009 | 08:15 PM
jjollysc31's Avatar
when i crank it the rpms immediately redlines and the limiter kicks in.....runs full throttle
Old Jul 4, 2009 | 08:21 PM
jbrew's Avatar
Does it start ? WTF ?
Old Jul 4, 2009 | 08:23 PM
jjollysc31's Avatar
yes it starts and runs full throttle until i turn the ignition off
Old Jul 4, 2009 | 08:27 PM
jbrew's Avatar
That's better -
Might be the Throttle cable or bad MAF.
Did you disconnect the battery thru the entire process?
Did you remove the throttle plate?
Did you replace ALL gaskets ?
Did you follow all instructions/procedures from this site?
Old Jul 4, 2009 | 08:31 PM
jjollysc31's Avatar
thats strange, will check in the morning......was driveable before. Thanks
Old Jul 5, 2009 | 09:26 AM
jbrew's Avatar
Wait a minute. Did you remove your throttle body spacer? If so, you have to reset the linkage.
Old Jul 5, 2009 | 11:48 AM
Veteran: Army
he probably removed his worthless TB spacer but didn't remove the bracket that holds the TB cable out further
