choppy idle
Old Jun 27, 2009 | 10:29 PM
BIG.D's Avatar
choppy idle
I have a 93 f150 with 302 and was wondering if theres anything i can do to give it a choppy idle sounds like a hot rod.
Old Jun 27, 2009 | 10:53 PM
jbrew's Avatar
- That's all in the Cam @ idle, but the more she's built, the better she sounds.
Old Jun 28, 2009 | 12:02 AM
BIG.D's Avatar
I was told i cant put a performance cam in my motor because it doesnt have a MAF sensor.
Old Jun 28, 2009 | 12:45 AM
Pull a couple plug wires.
Old Jun 28, 2009 | 08:23 AM
Tumba's Avatar
or 3
Old Jun 28, 2009 | 09:02 AM
Matts ford's Avatar
thats not totally true. it depends on the cam. you cant go too serious with the cam with the stock tune. but you can get it tuned for it. i think the custom computer chips are able to tune it and they are easy to install. just unhook the neg battery cable and pull the ebrake bracket off(3 nuts, 1/2" socket i believe) and there is a little opening in the back of the computer for the chip. superchips has the custom chips and i think hypertech does them now. that or you can get it dyno tuned for it. my trucks got a jasper class 1 performance engine(just a little bit bigger cam) and i have a speed density system too with the stock computer and a hypertech chip(not the custom one though, that will be later on). no problems here.
and i've seen a guy unplug his iac and drill the hole in the throttle plate bigger(so it stays running) to get it to idle lower to try to get a similar sound
Old Jun 28, 2009 | 01:04 PM
Veteran: Army
there are conversions for running a MAF on your truck
you can always go to long tubes, an H-pipe and flowmaster mufflers for a choppy sounding idle compared to what it now but nothing will replace a cam sound
