Water in the valley behind alternator
Old Jun 13, 2009 | 09:22 AM
Chrisoswald's Avatar
I had a little puddle of coolant on my driveway when parking on a steep incline....Well i figured out where my seepage came from...looks like i have some coolant pooling in the valley behind my alternator...any ideas where it could be coming from and what is the fix?? thanks guys
Old Jun 13, 2009 | 09:56 AM
150xlt's Avatar
Their is a nipple sticking out of the block behind the water pump that the coolant tube connects to. It is the tube that is on the back passenger side of the motor. Their is two o-rings on the nipple, maybe on of them is bad. Hope this helps
Old Jun 13, 2009 | 12:46 PM
jbrew's Avatar
https://www.f150online.com/forums/v8...lant-leak.html
Old Jun 13, 2009 | 01:50 PM
Thanks Jbrew...anything you suggest i should replace while this is torn down?
Old Jun 13, 2009 | 02:17 PM
jbrew's Avatar
Just gaskets, - a Torque Wrench that reads inch pounds will be needed. You have to tighten down the intake correctly or she'll leak.
Old Jun 13, 2009 | 04:01 PM
got it...thanks!!!!
Old Jun 13, 2009 | 05:35 PM
Camarothatcould's Avatar
tighten down intake correctly or it leaks. lolz
Old Jun 13, 2009 | 05:41 PM
jbrew's Avatar
Yep, at least two stages - I do 3 myself w/new gaskets. The heads have to be bone dry and free from any foreign matter, specially oil.
