Cylinder #7 Misfire????
So i have a 2000 F150 5.4l with 76000 miles on it and i recently had the number 7 spark plug blow out. $500 later got it fixed and it has missed since then. Somedays its not bad other days its horrible... i dont know what to do, ive changed plugs, coil packs, ran fuel cleaner through it, and the seafoam stuff. Recently i have cleared the misfire codes and it still runs like crap but wont code it. At high RPMs it starts to shudder and the Service Engine Soon light flashes a couple times but then eventually goes off. Ill take any help i can get!
Thanks,
Jeremy
Thanks,
Jeremy
What Plugs
Hey this happened to me what did you use this happened on the motor craft they said it was only the one plug but i replaced them all again but with the champions they did the labor for free since it was just done but i did have to pay for the plugs
Install Motorcraft plugs .
Jump on eBay, purchase COP's ( 8 or 10 set) from Global auto or Uneek Supply. (NOT coil pacs- 5.4L's do not use coil pacs).
Install coils.
She'll be runnin like she should.
If you need help with the install, just ask once you get the parts, -we'll help yuh.
Remove the Bosch Platinums.
Install coils.
Install coils.
If your in a hurry, run to your local NAPA and purchase a new COP (coil over/on plug) for $58.00 and get a new MotorCraft plug in there. If you haven't already, order a set of COP's from Ebay and replace all of the COP's as soon as you can. I would replace the Bosch's with MC's when you do the change.
cool thanks guys, ill try the new coils and plugs. But unfortunately napa just closed
so it will have to wait... Is there anything else i can do in the mean time? The Mechanic that replaced the blown out plug said that it could be a piece of aluminum causing low compression, thus a misfire. Is there anything i can do to take care of this????
so it will have to wait... Is there anything else i can do in the mean time? The Mechanic that replaced the blown out plug said that it could be a piece of aluminum causing low compression, thus a misfire. Is there anything i can do to take care of this????UGGGG!!!!!!!!!!.....I really hope the mechanic used a bore scope and looked into that #7 cyclinder after he did the repair. The other thing he shoud have done is left the plug out of the #7 cylinder and tried starting it, to "possibly" blow out any debris that may have been in that cyclinder after his repair.
Did he use a heli-coil to repair that cyclinder. Find out what he did to inspect and remove any possible aluminum shavings after the repair on that cyclinder. Your mechanic needs to check compression on that cylinder before you go throwing parts at it.
dont get all tensed up just yet. just swap the #7 coil with the #6 coil and see if the misfire moves. when the plug blew out did the coil blow off the mount? maybe it screwed up the harness connector to the coil. and for the cop's just type in dg508 in the ebay search bar. and make sure you torque the new motorcraft plugs to 28 ftlbs. and just in case #7 is the 2nd cylinder from the very back on the driver side. with that said, did you change the plug/coil for cylinder 7?
if the coil you placed in the #7 spot was good then the coil isnt the problem. what brand plugs do you currently have in the engine? is it still bosch? with a good coil on #7 you could do as tjk said and check the voltage to and from the coil. and the same thing with the injector. and just an fyi, if that mechanic used a helicoil, he may have screwed a valve(view pic in the link below). and may i ask what the exact code was? was it the p0307? or was it a circuit fault code?
clearances are very tight on the modular engines.
http://www.blownoutsparkplug.com/images/100_8593.JPG
Is that Tap clearing the valve. From the picture angle, it looks like it is hitting the edge of the valve. Do you have the written article that goes with that picture that I could read.
Thanks,
TJK
