wanting to do a motor swap
Old Jun 7, 2009 | 01:43 PM
f150fella08's Avatar
2002 4.6 and i want a 5.4, how would a 3v fit in there, and what all would i need to replace, torque converter? exhaust manifolds? transmission? would everything plug up if i got a 2v 5.4
my 4.6 is pretty weak and i need it to pull trailers and stuff
Old Jun 8, 2009 | 01:58 PM
Veteran: Army
look at the thread started by 01roush
look at the swap notes posted by JMC
a 5.4, either 3 valve, 2 valve or 4 valve will bolt into your truck, the 4 valve or 2 valve being the easiest to get running as the 3 valve will require locking out the VTC or the 3 thousand dollar plus install kit from ford
a 2 valve or 4 valve will be easy and you can re-use some of your parts
Old Jun 8, 2009 | 06:57 PM
thanks buddy i tried the search before i started this thread and nothing came up
