Fuel Filter??
Old May 19, 2009 | 08:40 AM
kjf-150's Avatar
Smile Fuel Filter??
How often should the fuel filter be changed? By reading around some ppl say 10,000k, some say 100,000k. I have 55,000k on my 07 F-150. Does it need a new fuel filter?
Old May 19, 2009 | 09:34 AM
mikebaby's Avatar
I thought that Ford recommended 25k intervals
mikebaby
Old May 19, 2009 | 09:36 AM
I change mine every 20,000. If you saw what runs out of the filtered side, you would change it. Nasty. They are cheap and takes about 15 minutes, so why not?
Old May 19, 2009 | 09:50 AM
05_sprcrw's Avatar
+1 ^^^^
I about had a heart attack the first time I changed that out.
Old May 19, 2009 | 10:05 AM
kjf-150's Avatar
Thanks guys, I'll change it out next time I change the oil.
Old May 19, 2009 | 10:12 AM
If you have never done it before, use the Search feature and there should be lots of help. You need a special tool that costs about $10 or less and I pay about $13 for Motorcraft filters. The dealer gets $69 for a change and the quick lube joint gets $49.
Old May 19, 2009 | 11:16 AM
kjf-150's Avatar
What does this tool do? Where do you get it? Is is possible to do it without it?
Old May 19, 2009 | 11:36 AM
My be possible, but you don't want to try it. It's a line release tool, same as used for air conditioning connections. There are two types, a metal one and a plastic. The plastic works better as it is thinner. It slides up in the hose and releases a clip. All parts stores carry them.
Old May 19, 2009 | 11:38 AM
This link is from our How To section.
https://www.f150online.com/forums/ar...picturess.html
Old May 19, 2009 | 11:43 AM
Look at post 18. nasty.
Also the metal tool is shown and then look at post 68 to see the plastic version. I highly recommend the plastic. I had the metal and had to go back and get the plastic. The metal one is too thick on some filters.
