Coolant drain plug?
Old May 1, 2009 | 10:26 PM
wutagoalie's Avatar
Coolant drain plug?
Hey guys, ive looked everywhere and cannot find the coolant drain plug on the block. Im looking on the drivers side, does anyone have a picture to guide me in the right direction?
99 4.6 v8 2WD
Old May 1, 2009 | 10:36 PM
Skaz's Avatar
In a brilliant engineering move, ford placed it right under the motor mount!! lol
Old May 1, 2009 | 10:45 PM
jbrew's Avatar
Post #10 -
https://www.f150online.com/forums/v8...ntifreeze.html
Old May 1, 2009 | 10:59 PM
Skaz's Avatar
Ok thats weird cuz in the pic on that how to the drain pug is further back towards the tranny than mine. Mine is forward a cylinder right underneath the motor mount? Must be because its a 5.4 and mines a 4.6. Or maybe romea vs windsor? The OP has a 4.6 so if you dont find it where its shown in the how to look under the motor mount. I hope your lucky and its not.
Old May 1, 2009 | 11:06 PM
jbrew's Avatar
That would suck under the motor mount , - the only way I could get mine to rewind out of there is with the impact. If it was under the mount, that would be fun lol.
If I remember right, I use two long *** extensions w/swivel in between - backs right out.
Old May 1, 2009 | 11:13 PM
Skaz's Avatar
Huh yea that must be another difference between the 5.4 and 4.6. ****ing 4.6. lol
Old May 2, 2009 | 12:02 AM
wutagoalie's Avatar
Finally found it, the problem was, under my truck in one big pile of rust. All along i was looking for an alan key hext style nut. It was a regular Bolt style head. Not sure what the motor mount looks like. The closest thing to it was an orange type electrical plug? Anyways i found it and the coolant i drained was the first time ever. 370,000 km. Looked like hell water.
Old May 2, 2009 | 01:37 AM
jbrew's Avatar
Better than a Hex head. Yea, I would have been looking that as well lol.
The Orange plug is probably for a block heater, unless it's a just dead connector hanging from the harness. - That's a steering assist connector. Our trucks didn't get that option lol.
The Oil pressure sender is down there as well.
Motor mounts- connect the motor to the frame rails. Their basically a large piece of rubber located between two pieces of steel.
Flush her out good
Old May 2, 2009 | 04:45 PM
tom-rad's Avatar
how about a stuck (never removed) plug?
any advice? Guess the motor should be hot? I have been soaking mine w/penetrating oil for a week.
Old May 2, 2009 | 04:47 PM
jbrew's Avatar
That's what an Impact is for. - I don't have to crawl under - a couple extensions and go right thru the wheel well.
Unless yours is under the mount, then I'm not sure- haven't had that experience...-thankfully lol.
Old May 2, 2009 | 04:56 PM
tom-rad's Avatar
ok, thanks.
I did try impact on it last weekend, ended up breaking a standard socket (I have the 3/8" piple plug (square head) type).
Thanks for reply, I'll try it again today, since the oil has been soaking in for a week of driving. Need to get the cleaner & distilled water out of it.
Old May 2, 2009 | 05:55 PM
Roadie's Avatar
If the plug is steel and the block is cast iron, you not ever get the plug out. I just drain the radiator and do it every year instead of every 2 yrs for the green antifreeze.
Old May 2, 2009 | 06:09 PM
jbrew's Avatar
Yea, you need an Impact socket lol.
Old May 3, 2009 | 01:00 AM
If you can't get it out, install a Prestone flushing tee kit and flush it that way.
Old May 3, 2009 | 01:40 AM
Roadie's Avatar
Don't put tap water in the cooling system, even for flushing. The minerals in the water will plate out on the cooling surfaces when it gets hot.
