Starting issue
Old Apr 8, 2009 | 11:04 AM
prescotti67's Avatar
Talking Starting issue
has any one ever had an issue starting the truck. Starts first thing in the morning, runs great, shut it off for a short time and then it will not start. Let it set for a spell and bam! starts and runs like a champ! This does not happen all the time but you never know when ity is going to happen, it is a guessing game. Perhaps a CRANK/CAM sensor issue. I have done some reading on this on the internet, a lot of the findings point to Crank/Cam sensor but I am not a mechanic so I do not know for sure. I posted this in another section and was suggested to post in this engine thead as well(thanks jbrew). It does not just stall when running nor do I get a check engine light, does any one have any ideas as to what the heck this is? I have a 1998 F150 4.6L V8 Triton 4x4 ext cab and this is the only issue that I am having, I love her and dont want to put her down, please help.
Old Apr 8, 2009 | 03:49 PM
Matts ford's Avatar
sounds like somethings overheating to me.
does it happen often? check fuel pressure next time it happens if you can. maybe rent a fuel pressure gauge from autozone if they allow it, and when it happens check the pressure. if its not fuel then check for spark.
Old Apr 9, 2009 | 07:44 AM
Cool Starting Issue
Do fuel injected engines get "vapor lock" or is that just a carborator thing? I am about to just pull the engine and put a new one in... So confused, any help is apperciated. Thanks
Old Apr 9, 2009 | 08:00 PM
Matts ford's Avatar
yes they can get vapor lock
Old Apr 9, 2009 | 08:29 PM
jbrew's Avatar
I know they will not start with new injectors unless you hit the shrader one time.
Also, if you crank the motor more than 5 seconds and -No start. It's not going to. The PCM shuts down the injectors to protect your cats.
Either come back later (needs to reset) - or pull the PCM fuse (disconnect battery). In other words - "Re-boot".
She won't start if the regulator is acting up aswell. To much pressure at the rail will cause a No start.
I thought I told you all this in the other forum and thread you have goin ?
https://www.f150online.com/forums/19...ing-issue.html
Right ! I did. Sounds like your regulator to me.
Actually under troubleshooting , problem with warm starts it lists one thing - Regulator. So aparaently, your not taking the info seriouse? Or not telling use what or how you tested. What gives? Did the regulator pass? What were the number variations -vac on/vac off? Do you honestly want help lol?
Old Apr 10, 2009 | 11:56 AM
srfd44's Avatar
I have been chasing this one down also, same exact symtoms
I verfied that the pump is not working when it don't start. You spray starting fluid in the air intake and it runs for a while.
Checked fuses, relay, and connections, all good.
I think its time for fuel pump replacement. What baffles me is when I wait it will start up. You figure when the pump dies, it's down for good.
I did not try to reset the PCM, will try that before the pump replacement
