Rough Idle help?
Old Apr 1, 2009 | 08:49 PM
alltat2ed's Avatar
Rough Idle help?
Hi guys, I'm new this forum and I need some help.
I have an '05 F-150 FX4 5.4L with 48K miles. It was idling rough so I took it in for a tune up (I wasn't attempting those plugs after all the horror stories). After a $500 tune up with 2 new fuel injectors it is still idling rough and the mechanic says if it isn't throwing a code there is nothing he can do. He said coil packs are good. IAC valve maybe, but is there anyway to know for sure without buying the $60 part and swapping it out? Any ideas?
Old Apr 1, 2009 | 09:21 PM
truck man's Avatar
with the engine running wigle some wirers under the hood maybe the mas air flow sensor wirers, maybe o2 censor did they hook it up to a diagnostic machine? maybee the service engin soon light that tells you a code is being spit out is out just some ideas off the top of my head
Old Apr 2, 2009 | 01:15 AM
jiggle's Avatar
Be sure to check for vacuum leaks. A quick shot of carb cleaner into the engine compartment will tell you if you've got one.
Old Apr 2, 2009 | 01:24 AM
SHSUFord's Avatar
if you have underdrive pulleys and have not set your idle higher that would do it
Old Apr 2, 2009 | 08:09 AM
The injectors on 05 5.4's are under extended warranty - you may still have some leakers.
