Not Starting
Not Starting
Ok so last post i made wasn't very helpful but
'02 F150 82k miles on it
here it is...it doesn't start directly up in the afternoon hours the engine turns over when i turn the key, But it does start up after the second or third try
i was told by one that i should replace the fuel pump filter but i don't know how or where that is located
Buy a haynes chiltons or other repair manuel for your truck. They arent maintenance free. The book will help you do basic maintenance and will pay for itself many times over. I replace my fuel filter every fall. Its by the frame rail on the drivers side. You need a special tool you can get at autozone for 10 bucks. the book will show you how to do it.
If the fuel pump filter is the same thing as the fuel filter then i believe its on the inside of your drivers side frame rail
and if i were to take this to an autoshop and get it done how much do you think it would cost?
About $45 at a quick lube joint for a fuel filter. My dealer charges $69.
i'm pretty sure it might has been changed ONCE lol
so ill go get that done, would getting it changed help with the starting up correctly or ? do you know lol
Well, it will help only if it isn't starting because the filter is stopped up and starving it for fuel. It needs to be changed regardless, so you will not be wasting your money.
Alrighty, a week or so ago i replaced my Fuel Filter and for a tad bit the "not starting" seemd to go away
but now its back and very frequently...if i drive the truck and then do something for about an hour or more it just doesn't start up like it should...its even happening at night and morning now, if anyone could tell me what this is i would LOVE to find out and get it done now
i've tried pumping the gas petal a bit and turning the key to the battery mode right before it starts and sat there for like 5 seconds most nothing seems to work, i would relaly like to get this fixed before i head off to college in about 3 months
