Backfiring
Timing is off. Set the timing at 8 degrees BTDC. Also check the carb and make sure no fuel is just dripping when it is at idle. Excessive fuel and a retarded ignition timing causes this. The timing chain has stretched over time and makes the distributor "off". Not a big deal.
