ticking
Old Mar 26, 2009 | 11:09 PM
mike2252's Avatar
ticking
I have a 2001 5.4, truck runs good but when it warmed up the shut off for about 15min or so then restarted there is a charting sound then while driving for arourd one min there is a slight tick. Is this normal. Its done it since I owned it at 90,000mile and has 105,000 on it now.
Old Mar 26, 2009 | 11:42 PM
20Screw01's Avatar
Run it until it blows up. Is it drivers side or pass side?
Old Mar 27, 2009 | 10:23 PM
mike2252's Avatar
sorry it took so lone to reply was working. it sounds primarly on the right side
Old Mar 27, 2009 | 11:01 PM
4play2008's Avatar
yeah thats probably piston slap, dont worry about it unless it gets alot worse
Old Mar 28, 2009 | 05:39 AM
To be safe, I'd check to make sure none of the spark plugs are loose and backing out.
Old Mar 28, 2009 | 10:19 AM
mike2252's Avatar
thanks for the info will check pluggs
Old Mar 28, 2009 | 11:14 AM
mike2252's Avatar
Checked all pluggs and they are tight. could it be from running cai, exhaust, and 93 octane gas with out a tune?
Old Mar 28, 2009 | 11:45 AM
jethat's Avatar
Piston slap is not uncommon just an annoyance. 5.4's will last for hunsreds of thousands of miles with it my kid thinks my truck has it but I cant hear it(deaf...) Dont worry about it to much.
Old Mar 28, 2009 | 03:35 PM
kakings's Avatar
Had similar tick. Found out two days ago that it was a loose plug (after it blew out). Now I'm looking to for a replacement motor, since the blow out stripped the threads in the head. Make sure that your plugs are tight. Will save a lot of $ and trouble in the long run.
Old Mar 28, 2009 | 04:02 PM
jethat's Avatar
Why not get a timesert installed? I've had a plug blow out in my van dealer fixed it and I havent had a problem with it since and that was 5 years ago.
Old Mar 28, 2009 | 04:44 PM
Matts ford's Avatar
if the plugs are coming out then torque them to 28 ftlbs. that'll keep it from happening again. actually its a good idea to torque them to 28 either way just so it doesnt happen at all.
Old Mar 28, 2009 | 07:56 PM
Camarothatcould's Avatar
I think you mean "Re-torqueing" them, you cant torque something that tight already and expect it to be torque at that specific ft, lbs. Sure the plugs might be in there say 15- 20 pounds, but it might take over 50 ft lbs to move em. In short, break the plugs loose, then torque
Old Mar 28, 2009 | 08:18 PM
Matts ford's Avatar
yea true. thats what i meant but i worded it wrong i guess. oh well thanks
Old Mar 28, 2009 | 08:57 PM
Bent6's Avatar
25 Year Member
Also check the rearmost exhaust studs. The studs heads pop off and create a exhaust leak (tick) till the engine warms up.
Old Mar 28, 2009 | 10:44 PM
mike2252's Avatar
will check manifold tommorrow
