Siting at Taco Bell and It wont start
Old Mar 24, 2009 | 04:36 PM
craigooo's Avatar
So I just put gas in it and washed the truck and now it wont start. Just a light rinse nothing fancy with the engine or anything. It started at first but idled around 250 rpms (yes that low) and then just shut off,now it wont start at all. Any help would be appreciated
Old Mar 24, 2009 | 04:43 PM
Matts ford's Avatar
motor? mileage? how olds the fuel filter? when it idled low did it still drive normal? do you have any kind of tuner? did the engine get wet at all? do you hear the fuel pump at all? have you tried giving it a little bit of gas while cranking it? have you tried priming the fuel pump a couple times before cranking? does it even crank at all?
Old Mar 24, 2009 | 04:48 PM
daves03's Avatar
Fuel
Yea basically what matt said, we need a lil more info. If its the fuel pump you should be able to go and have someone crank the truck over while you pound on the fuel tank with a hammer. (modestly) try that and see if it starts if it dose its your fuel pump, if it trys to start its your fuel pump. Let us know.
Old Mar 24, 2009 | 04:50 PM
craigooo's Avatar
Its got the 5.4l 168,000 miles. I changed the fuel filter at about 150,000. No tuner nothing aftermarket at all. The engine is dry. It ran fine coming in after sitting about 5min, it just wont start. Seems like it wants to but wont.. like there's no gas. But if I let it stand for 5 or so min. it will try and turn over, but then dies. I just checked some of the fuses. Is their one for the fuel pump, I assume so but dont know where. Thanks in advance.
Old Mar 24, 2009 | 04:58 PM
Matts ford's Avatar
it may end up being the fuel pump driver module. they are rusting out causing them to fail. its above the spare tire on a cross member.
Old Mar 24, 2009 | 05:02 PM
craigooo's Avatar
Is their anyway I can get it started without towing it you think? Thanks for the help, and taco bell for having free wifi.
Old Mar 24, 2009 | 05:05 PM
Matts ford's Avatar
i'm sure you could but we'd have to figure out whats wrong to be able to help you out.
Old Mar 24, 2009 | 05:12 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Same thing happened to me a month ago.
Acted like it was starved for fuel.
Called for a tow but, had to wait two hours.
The tow driver knocks on the window, wakes me and says,
"You what what Ford spells backwards? Driver returns On Foot."
He steps in and says, "Let the magic Chevy hand try it."
It fired right up.
Moral is, if your strapped for cash let the truck sit a couple of hours.
Old Mar 24, 2009 | 05:15 PM
Sure sounds like it could be a fuel filter stopping up. With 18,000 on the filter, it's probably dirty and maybe some bad gas just finished it off. He just bought gas.
Old Mar 24, 2009 | 11:09 PM
craigooo's Avatar
Its the fuel pump driver module, Its corroded pretty bad and broke in half some how. Ill be replacing it tomorrow. Thanks for the help.
Old Mar 24, 2009 | 11:16 PM
Glad you found the problem.
Old Mar 25, 2009 | 08:38 AM
srfd44's Avatar
Does my 98 4.6 have this driver?. All I see back by the spare tire is the cabon canisters for the vapor stuff. I would like to check this out because I am having the same problems
Old Mar 25, 2009 | 09:13 AM
Dogzilla's Avatar
A little bit of STP gas treatment will fix many problems, and regular use of the stuff will flat out prevent them.
Water is pretty nasty stuff in the fuel system, and the STP takes it all out. Cheapest insurance you can buy.
Old Mar 25, 2009 | 02:16 PM
Matts ford's Avatar
no the fuel pump driver module is on returnless fuel systems yours is a return system. how old is you fuel filter? are you able to hear the fuel pump? are you getting any fuel to the rail? if so how much? are you able to hear the relay and can you jump the relay? are you using the factory key?
Old Mar 25, 2009 | 03:19 PM
srfd44's Avatar
Thanks Matt,
I wrote another email about the same problems the OP posted, checked the relays, fuel filter is new, Air Control Module is new.
When it does not start, I cannot hear the pump. But wait an hour or two and it starts like nothing is wrong. I am afraid I will be changing the pump but am confused as this is not a complete failure as I expect the pump to be. Why does it go if I wait an hour, it should be dead all the time.
