5.4L engine question
Last weekend was towing my trailer and started going up a grade then the engine started rattling, sound like it was coming from the top end. It then started loosing power so as I let off the gas to a certain point it went away but everytime I would give it gas it would start making noise again. At one point the "check engine" light started flashing it then went out after about 30 seconds. I had this happen once before while towing this trailer. I was running middle grade gas due to a modifiyed tune. Without the trailer I cannot get it to duplicate the noise and it seems to run fine. I used my programmer to check for codes the day after this happened but came up with nothing. Any clues on what is going on?
do not run a higher octane gas on a lower octane tune.
it is ok to use a lower octane gas on a higher octane tune as long as you dont get detonation or pinging. i have my truck tuned for 89 and use 87. i think i get a little more out of it.
think about it. octane pretty much means how easy it is for the gas to burn. a higher octane means the gas is harder to burn. so if you put a lower octane in (easier to burn) you, in theory, are getting a more complete burn.
