no start 2005
Old Mar 9, 2009 | 08:36 PM
fallingfowl's Avatar
no start 2005
hey every one. have a 2005 f 150 super cab 4x4 that has no power to fuel pump. checked pressure, was low, used to set code for fpr. (fuel pressure regulator) when it was running, but running bad. did put pump in it, started it, ran for about 30 seconds, stalled now no power at pump! help please
Old Mar 9, 2009 | 08:48 PM
4play2008's Avatar
doubble check your connections maybe it unplugged it's self or maybe the fuse blew?
Old Mar 9, 2009 | 08:53 PM
did check all fuses with test light, i unplugged it to test power also. owners manual didnt point out what fuse and relay for pump, did test all fuses with key on thou
Old Mar 10, 2009 | 02:53 PM
Matts ford's Avatar
how old is the filter? sounds like the fuel pump driver module is bad. its somewhere near the spare tire. i dont know where you live but the fuel pump driver module doesnt get along with salt and they rust through and they go bad.
sounds like the exact same problem as this https://www.f150online.com/forums/en...any-ideas.html
