Brain teaser...
Old Mar 5, 2009 | 09:52 PM
Quintin's Avatar
Coils aren't causing your lean condition.
Originally Posted by JayPhoenix
The maf may be the source... it's attaching screws aren't attached real well i noticed... it's been siliconed onto the duct piece lol...
That ain't gonna work.
JayPhoenix's Avatar
in Lloydminster, Alberta
Old Mar 5, 2009 | 09:56 PM
Gotts2BMe's Avatar
Ic i have a bunch of extra coils, injectors, O2 sensors, if you want to give any of that a try all located just outside regina.
Old Mar 5, 2009 | 10:04 PM
JayPhoenix's Avatar
Thanks for the offer, i'll see if the MAF thing is the problem.. hopefully its simple.. would a 4.2 MAF and housing suffice as a tester, as I have my other truck right handy lol
Old Mar 5, 2009 | 10:07 PM
Quintin's Avatar
No.
Old Mar 5, 2009 | 10:13 PM
JayPhoenix's Avatar
greeeat figured as much, one more thing goes wrong this trucks getting gutted and going carb. not worth the headache at this point.
Old Mar 5, 2009 | 10:24 PM
jethat's Avatar
Why not just drop the thing off at the dealer and let them diagnose it? Modulars are great engine that last a long long time. Sounds like your in the learning curve with them. Stop torturing yourself and drop it off and let them tell you whats wrong. You dont have to have them fix it. Sometimes the dealer can actually save you money. This is one of them for you.
Old Mar 5, 2009 | 10:29 PM
Gotts2BMe's Avatar
what do you want for it? is it sask plated or alberta
Old Mar 5, 2009 | 10:34 PM
JayPhoenix's Avatar
lol that may be the case here, i've put a lot of time into this thing and so far no productive results... Gott's i'll let you know lol justa t the stress point. Will probably look at it come monday with a clear head. Thanks everyone and talk to ya soon.... ish
Old Mar 5, 2009 | 10:49 PM
jbrew's Avatar
Heck Quintin - Why bother, - Let him do a bunch a nothin lol, guess yuh goota learn somehow.
This one will prolly be one of those 20 pagers.
Old Mar 5, 2009 | 11:01 PM
tjk_in_cny's Avatar
Originally Posted by jbrew
I think it's a Bootist word or at-least Trible. ? I've heard it before at college - it would echo down the hallway at times. Chick sittin next to me said they had some type of meditation class down the hall.
I checked it out after class, I walked down to the end of the hall, - There wasn't No class rooms down there
Just a crapper
GOOD 1
Old Mar 11, 2009 | 01:31 AM
JayPhoenix's Avatar
Quick check, what year range on the 5.4's can i look into robbing the entire air inlet piping and sensors off of? I assume 97-03 should technically be the same but, seen some things have changed year to year on other motor's/trucks. So please anyone in the know let me know so i can figure this surging idle problem :P much appreciated
Old Mar 11, 2009 | 02:03 AM
Gotts2BMe's Avatar
All Ford IAT's are the same pretty much with the exception of the lightning which threads in. The MAF on your v6 is probably the same as the one on your 5.4 truck as well. Try it before you spend money on it.
Old Mar 11, 2009 | 07:32 AM
JayPhoenix's Avatar
Thank you thats what i was hoping to hear.
Old Mar 11, 2009 | 02:19 PM
JMC's Avatar
JMC
25 Year Member
You might find that the MAF on your 4.2 is metal and your 5.4 is plastic. While the size of the tube may be the same the Sensor is not the same. All the MAFs run from 0 to 4.5 volts. The airflow at idle on a 4.2 will be less than the airflow on a 5.4. If you put a 4.2 MAF in the airstream of a 5.4 the voltage signal at idle will make the sensor react like if a 4.2 was just above idle. The voltage signal sent to the PCM will be out of range with what the PCM is looking for and it will set a code. You will need to retune the MAF tables to compensate for this. If your plastic MAF sensor is not sitting properly in its place in the MAF housing it may skew the readings.
