Advice on 4.6 Engine Build
Old Mar 2, 2009 | 03:56 PM
phil6608's Avatar
I'm with JMC and Gotts,
Cost the same to build the 5.4 and you end up with more power and all kinds of options for supercharging!
There is a very limited supply of supercharger kits for the 4.6. Why spend all that money only to start off handicapped.
Phil
Old Mar 2, 2009 | 04:47 PM
JMC's Avatar
JMC
25 Year Member
What did you hit to crack the block like that? I have done some stupid shìt with mine, including 2 bent frames, but I never cracked a block.
Old Mar 2, 2009 | 05:53 PM
siriddler's Avatar
I'm not 100% sure when it happened, but I'm pretty sure it happened when I T-Boned a guy in a Corsica that turned left in front of me. I drove away, his was totaled. The shop straightened my frame and put on a new bumper, but I never noticed the cracked block.
Old Mar 2, 2009 | 05:54 PM
siriddler's Avatar
How are you coming up with your figures?
All I need is a block and rotating assembly for the 4.6 rebuild.
With the 5.4 I need a computer, tune, wiring harness, exhaust, intake, the list goes on and on.
It's more expensive to do the swap....
Old Mar 2, 2009 | 06:28 PM
phil6608's Avatar
A block ,rods,crank,and pistons are about the same price.
You don't need a 5.4 computer,your computer will work.
Your going to need a tune anyway,,,PI 4.6 is not going to run proper with a non PI tune!
You can use your wire harness,,,but for a 5.4 wire-harness and an intake manifold,,the price is very reasonable considering the extra power.(lot of guys have that stuff just laying around looking to get rid of)
You would only need to weld a very short piece of exhaust on to make that work.50 bucks at any shop probably.
If your thinking of putting in forged parts,,,you must be thinking of supercharging.
Only thing for the 4.6 is a centrifugal or turbo.
The 5.4 you can get a centrifugal,turbo,twin-screw,or roots blower!
It's your truck,,you do what you want.We are just trying to give you some good advice!
Phil
Old Mar 2, 2009 | 10:28 PM
siriddler's Avatar
Phil
Don't take my post the wrong way, I appreciate all the help!
We'll see what happens, you never know what I might do!
Old Mar 3, 2009 | 10:55 PM
Typow07's Avatar
This is awsome ive always thought about maiking a 4.6 higher performance.. like the audi 4.2 is one of the most powerful v8s in the world... makes you think
Old Mar 4, 2009 | 11:41 AM
siriddler's Avatar
The 4.6 can make the HP I want just as easy as the 5.4, only it won't be in the low end, which is fine with me since I have a stick.
The problem I am having is finding the 4.6 Windsor Block. The Romeo is easy, but the Windsor I will have to go to a junk yard which doesn't thrill me.
My other option is to get the Romeo and the Forged Internals for it.
Old Mar 4, 2009 | 12:24 PM
siriddler's Avatar
Will a '97 Mustang 4.6 block work?
Old Mar 22, 2009 | 08:14 PM
Zero2005's Avatar
Phil
uh kenne bell?
Old Mar 22, 2009 | 09:34 PM
phil6608's Avatar
Originally Posted by Zero2005
uh kenne bell?
Uh,,yeah,,,if ya want to try to customize a Mustang kit in a truck.
KB dose not make a kit for the truck anymore. You would have to find a used kit and I had one and was not impressed with it.
http://www.kennebell.net/supercharge...r-selector.htm
Phil
Old Mar 31, 2009 | 02:03 AM
Jesster's Avatar
Bump... This is an interesting thread as I have some of the same questions and thoughts on going from a 4.6 in my 99 to a 5.4 or stroke the 4.6. Siriddler, any progress on your project?
Old Mar 31, 2009 | 07:04 AM
Veteran: Army
i pretty sure JMC and Phil said it as best as it can be put, since your getting a new intake manifold anyway all you'd need is the 5.4 front cover and you'd have a better platform to start with and upgrade on later down the road
Old Apr 6, 2009 | 07:36 PM
siriddler's Avatar
Jesster,
I will keep the thread updated, the project got put on a small hold... The hardest part of this project is finding a Windsor block. They don't make them anymore so you have to get a Romeo block if you want to go new. The problem with this is that the Romeo block is cast different so your Windsor internals won't work with it.
As far as the 5.4 hype, I don't buy it. The 4.6L build is just as good as the 5.4 minus the aftermarket community. The 5.4 can potentially have more torque than a smaller motor but HP is going to be the same and I already have a lot of the parts to work with.
I still plan on doing this soon, the woman wanted a deck and pavers for the patio so I put the truck on the back burner, but I'm almost done with that project and can focus once again on the truck.
Old Apr 17, 2009 | 01:33 AM
Folmar150's Avatar
I have seen 5.4s priced from $800 with 90K to $1,200 with 60K. Just find the deals. I would do they swap but im waiting and will just buy a supercrew.
