1998 f150 hydrolock help????
After 1-15-98 you are good. Thats what was quoted in FORD TSB on this issue. But keep this in mind. Check your coolant level in the overflow bottle when the motor is cold. Top it up to the Cold fill mark, after that check it every day for about 2 weeks. if you notice the level going down and there are no visible leaks then you may be starting to have the leaking issue with the Timing cover gasket.
