hole in fuel tank...help!
Old Feb 23, 2009 | 10:06 AM
grizzstang's Avatar
Originally Posted by RacingJake
Use a self tapping screw that's bigger than the hole. Put a big rubber washer on the screw and tighten it down. Then mix up some fuel sealer and spread it around the top of the screw.
This method works very well. I did this on an old beater and it never did leak.
Old Feb 23, 2009 | 10:23 AM
bigbronc's Avatar
Only problem there is the old beater didn't have a super sensitive EVAP system to check for any kind of leaks and make a CEL come on.
Old Feb 23, 2009 | 11:26 AM
dux20's Avatar
Thanks for the advice guys. It is in the shop as we speak. And a correction to my original post...it was a 3/16" drill bit, not a 5/16".
I'll let you know the outcome.
Thanks again.
Old Feb 24, 2009 | 10:29 PM
dux20's Avatar
The damage was done and a very expensive lesson was learned. Thanks to a 3/16" hole, I had to drop $1k for a new tank and labor. Note to all...don't drill on the driver's side of the truck.
And now, I will do the walk of shame! Thanks for the advice.
Old Feb 24, 2009 | 10:39 PM
JWBFX4's Avatar
wow! Ouch! Ive seen a good bit of used ones around here go pretty cheap out of the junkyard.
Old Feb 24, 2009 | 10:47 PM
Barrett's Avatar
Ouch! I hate learning things the hard way.
Don't drill this tank, dont think your wallet will like you much if you do!
Old Feb 25, 2009 | 12:30 AM
warrantyvoider's Avatar
if youre going to buy a new tank, just put a lot of tape on it till it gets there. what is the big deal? gas is not going to spill out of it everywhere. drive witha quarter tank all the time if youre worried.
Old Feb 25, 2009 | 09:20 AM
tjk_in_cny's Avatar
A bit late with your advice, he replaced the tank with a new one already.
Old Feb 25, 2009 | 12:26 PM
dux20's Avatar
I thought about the boneyard route, but working in corp america and having two young kids...I didn't have the time to go searching for a used tank...trust me, it definitely crossed my mind when I found out the price.
I figured it's a 3 month old truck and I made the mistake...so I gotta pay for it now. And it should keep me from having further issues down the road.
Old Feb 25, 2009 | 04:22 PM
tjk_in_cny's Avatar
You did the right thing by replacing it rather than band-aiding it. Like you said, it's a new truck, you won't make that mistake again.
Old Feb 25, 2009 | 05:15 PM
RacingJake's Avatar
Murphy's law says the day you get it back fixed some old lady will total your truck. So be on the lookout driving home
Old Feb 25, 2009 | 10:19 PM
tjk_in_cny's Avatar
What , What ???????
Old Feb 26, 2009 | 10:09 AM
dux20's Avatar
Really dude? Thanks for the karma!
