Does anyone know when Ford started putting PI Heads on the 4.6?
Old Feb 18, 2009 | 11:31 PM
Grayd73's Avatar
Question Does anyone know when Ford started putting PI Heads on the 4.6?
The tag on the valve cover says my engine was produced on 9/11/98(not sure if that's an OMEN or not), but was wondering if anyone knows when they started putting the PI heads on the 4.6L Romeo engines?
And what makes the PI heads "performance improvement"??? And can you put PI heads on if they weren't originally on the engine?????
Old Feb 18, 2009 | 11:42 PM
agbulet's Avatar
I believe PI heads started in the 99 model year. I know the cams are improved and the combustion chambers i believe are smaller which would yield a higher compression ratio bolted on a non pi short block.
Old Feb 19, 2009 | 01:05 AM
phil6608's Avatar
They started putting PI heads on the 5.4 in 99
Don't think the 4.6 got them until 01
Phil
Old Feb 19, 2009 | 01:33 PM
JMC's Avatar
JMC
25 Year Member
The 01 model year 4.6 got the Pi heads. The improvement in the port design improved the flow. The Combustion chamber is smaller and the cams are different.
Old Feb 19, 2009 | 08:41 PM
coobies5's Avatar
2001
Old Feb 20, 2009 | 12:23 AM
Grayd73's Avatar
Question
So can you put Pi heads on a non-PI engine?
Old Feb 20, 2009 | 12:51 AM
coobies5's Avatar
yup
Old Feb 20, 2009 | 02:26 AM
ONELOWF's Avatar
It raises the compression ratio to 10.5.
