Common Problem?
Old Feb 18, 2009 | 09:09 AM
abercrombie1's Avatar
Cool Common Problem?
New to this site, hoping to be able to figure some things out...I have an 03 F150 Supercrew, 5.4. it has been running a little rough latley, so i had check for codes, and got 2...P0172-system too rich bank 1, and P0304- cyl. 4 misfire. i have been told that told that cyl 4 goes out because the heater coil commonly drips on it??? Has anyone else had these issues? Thanks!
Old Feb 18, 2009 | 09:12 AM
FX41's Avatar
Welcome to the site. I've got an 02 with 113,xxx on it without any such problems.
Old Feb 18, 2009 | 09:27 AM
06 So Comfort's Avatar
Thumbs up
Your intel is correct. Rich condition caused my misfire. Cylinder #4 is next to firewall on passenger side, under heater hoses. Leakage on the COP, causing failure, has been reported on several occasions. Further searching will provide a source for the COP. I would recommend just replacing all 8 of them as a set.
Old Feb 18, 2009 | 10:08 AM
jackedf150's Avatar
I just had the same problem, replaced all 8 of my cop's and plugs and it runs like a champ now.
Old Feb 18, 2009 | 01:35 PM
Unhappy
Thank you to all who have replied! I had someone do a pressure test on the coolant system, because i have had to add coolent several times, recently, and testing revealed a leaking head gasket...ouch. thanks, again for all of the suggestions!
