gas milage????
Old Feb 7, 2009 | 08:48 PM
mera914's Avatar
ok thanks ill do that
Old Feb 7, 2009 | 08:49 PM
Soaring's Avatar
Originally Posted by Matts ford
just spray it with maf cleaner. then let it dry before you put it back in the truck
After you spray it with the cleaner, use a Q-tip to rub on the MAF, then let it dry and put it back together. Don't use so much oil on the K&N next time.
Old Feb 7, 2009 | 10:15 PM
jethat's Avatar
The K&N's really dont need to be cleaned that often they say there good for like 50000 miles. I think guys who buy them are generally the type that overkill on maintenance and on the engines that have MAF the oiling of the air filter obviously is a problem. You want to keep that to a minimum.
