How to test my Coil Packs
I have used the search but have found differing reports on what the primary and secondary readings should be. I also am not yet clear on exactly how I test. I have a 97 4.6L. Thanks in advance for any help!
you would hook an ohm meter to it. use the pic below to go with the numbers.
primary- hold pos lead on #6 and put neg on #5 and then after you get that reading put the neg on #7 to get your second primary reading.
secondary- put pos on #1 and neg on #3. then put pos in #2 and neg in #4 for your second secondary reading.
