Had codes read and it says....
Old Feb 7, 2009 | 07:35 AM
jackedf150's Avatar
Ok i will test IAC, I will have to go buy a ohm meter though. I have noticed when its just idling it doesn't sound that bad, you can tell it has a slight miss under no load when you rev the motor, when u put it in gear and and hit the gas and hold the brake it wont even think of spinning the tires on my smooth garage floor, That's when it is most noticible. Is it possible that the COP'S and plugs are shot without throwing a missfire code, but throw a p0174 code? I do have about 140k on the original cop's i beleive. Is there a way I can test the COP'S? I did notice when I took the cop's out #6 #7 #8 the spark plug wholes were full of water, I blew those out and let the cop's sit out for a couple hours before putting them back in but didnt seem to change much.
Old Feb 7, 2009 | 07:56 AM
tjk_in_cny's Avatar
Originally Posted by jackedf150
No I have hardley driven it anywhere since the light came on, less than 20min.That's good the code was a p0174 It read on the snap on modisvery nice tool, a friend who owns his own garage has the same unit, very nice tool it said bank 2 lean. the modis says the cop'sdidn't think the modis or any unit could read output voltage of a coil unless he was looking for general missfire problem and and injectors are fine and are within range with no misses, oxgen sensors are in range as well.Surprising, but this is good. The guy seemed to be leaning towards a vacuum leak. Do you have a vacuum diagram for your truck. You should have a sticker under the hood. If not, it will be a big help to you to buy a Haynes manual. We sprayed the mass air flow wires off with electrical cleaner and pulled the pvc.When you say, pulled the PCV, did you clean it and reinstall the PCV. 1 thing these trucks are notorious for concerning that P0174 code is a bad PCV elbow connector at the TB or a crack in the hardline plastic portion of the PCV assembly. Ford only part, and it will cost you $30.00+...I replaced mine last spring and it was the last thing I had to do to remove the P0174 code. after those two things the truck seems to idle fine and run better but when u are in gear giving it gas is when it starts acting like its losing power.I really think that drivers side CAT is toast. You have 2 CATS on that side. Are both glowing or just the upper.
Lastly, Again I say, check the IAC sensor out and eliminate it as a cause to some of your problems.
Good luck with it.
Old Feb 7, 2009 | 08:26 AM
tjk_in_cny's Avatar
Ok i will test IAC, I will have to go buy a ohm meter though.buy a mutil-function voltage meter and make sure it is a digital unit. They are costly but they have a ton of uses. Auto, home electrical etc. This way you have one tool on hand to work on your truck. You need the digital aspect of the meter to get acurate readings.
open link: http://us.fluke.com/usen/products/Fl...keUnitedStates, I own the older version on the right. I have had mine for better than 15 years and used to use it on a daily bases for work
I have noticed when its just idling it doesn't sound that bad, you can tell it has a slight miss under no load when you rev the motor, when u put it in gear and and hit the gas and hold the brake it wont even think of spinning the tires on my smooth garage floor, That's when it is most noticible. Is it possible that the COP'S and plugs are shot without throwing a missfire code, but throw a p0174 code?this P0174 code has alot of things that can contribute to throwing that code. The SnapOn Modis unit should have given the entire list of things to check for. I do have about 140k on the original cop's i beleive.Way over due for COP''s. go to this site on Ebay to buy your COP's, the price is excellent. http://cgi.ebay.com/ebaymotors/NEW-I...Q5fAccessories Is there a way I can test the COP'S? Again with a multi-meter, check the resistance of ea. COP, you should get a reading of 490 to 508 I did notice when I took the cop's out #6 #7 #8 the spark plug wholes were full of water, ding ding ding, we have a winner, this will definately be a big contributor of your problemI blew those out and let the cop's sit out for a couple hours before putting them back in but didnt seem to change much. Ye, you definately need to ohm those COP's. You really needed to put dielectric grease inside of the boot's on those COP's before it put them back in, and when you replace them make sure you use plenty of digrease in each boot.
This added info was a big help, sorry to say, you have some money to spend but your truck will be happy in the end for sure. Plan on replacing that CAT. If I had one that looked like a glow-plug, it would be gone and replaced ASAP.
Old Feb 7, 2009 | 08:29 AM
jackedf150's Avatar
i will check the pvc tube, i am not sure of the modis being able to check cop's, all he said was it didnt show a missfire so that would eliminate injector, spark plug, and cop problems. And yes both of the converters were glowing. But i will check the IAC here soon. have to wait for my boys grandfather to pick him up before i head to the store to get a ohm meter. Thanks for the help and Ill report back in a bit. Is there a way to test the COP'S witht the ohm meter to determin they are good or bad?
Old Feb 7, 2009 | 08:34 AM
jackedf150's Avatar
Ok I jsut read your last post, so you are saying that if the cop's are bad they can also throw the p0174 code instead of a missfire code? I dont mind the money aspect of it, but I refuse to take it to a place around here to do it when i am capable of following directions. And I am pretty mechanically inclined, well an excellent parts changer is a better word for it. LOL
Old Feb 7, 2009 | 08:38 AM
jbrew's Avatar
Make sure know one shoved something up your tailpipe lol - not kidding. Then get those cats off there pronto. Install new ones
Old Feb 7, 2009 | 09:04 AM
tjk_in_cny's Avatar
Ok I jsut read your last post, so you are saying that if the cop's are bad they can also throw the p0174 codeNO-not saying that at all. What I was trying to point out is that you check each coil for resistance of the coil to see if they are faulty. Place one lead on one of the pins on the connector end and one lead on the spring at the end of the COP boot instead of a missfire code? Yes it's possible to have bad coils and not throw a misfire code. Weird yes, but it happens. I dont mind the money aspect of it, but I refuse to take it to a place around here to do it when i am capable of following directions.Thats cool, don't blame you there. That and you get the satisfaction of saying you fixed it yourself with some friends from this Forum. Some of us are a bit nutty but that comes with the help, sorry And I am pretty mechanically inclined, well an excellent parts changer is a better word for it. LOLboth work for me
Do you have the tools to remove the CATS and replace them in your garage. This CAT problem is going to cause you more problems and probably make your repairs difficult by giving you bogus info and running conditions. If they both glowed RED, they are toast I believe. Jbrew knows a kid on this site who is an exhaust expert. Maybe he can chime in and help with this matter.
Old Feb 7, 2009 | 09:05 AM
jackedf150's Avatar
No there is nothing in the tail pipe, I was driving home from work at about 1am and the road was pretty much drifted shut, When I got home it was running great, when I came out the next morning and started it it is when the problem started. So i popped the hood and there was snow on top of the cops 6,7,8 and the air filter had snow around it. So i am still leaning Cop's are bad, but it messes with my head because there is no missfire code.
Old Feb 7, 2009 | 09:09 AM
jackedf150's Avatar
Well the cats are an issue for sure, any good suggestion or what to put in its place, ( cost affective not dealership prices). And from past experiences the nuts on the manifolds are a pain to get off right? There is a good exhaust shop 2 blocks from me.
Old Feb 7, 2009 | 09:31 AM
tjk_in_cny's Avatar
Well the cats are an issue for sure, any good suggestion or what to put in its place, ( cost affective not dealership prices). And from past experiences the nuts on the manifolds are a pain to get off right? There is a good exhaust shop 2 blocks from me.Take it to them ASAP. I wouldn't go OEM either in this case. I trust the products from my local ColeMuffler shop. Just so happens a highschool friend (Teddy)manages the place so I get excellent pricing.
The one thing I refuse to work on is the exhaust system unless it is a coat hanger emergency job. Well I do my own O2 Sensor work also.
Thankfully I have Teddy for my exhaust work. We actually own the same identical trucks. He's pee'd tho because his body was in better shape and then I had my truck completely done, body wise. Sorry for the rambling, bored waiting for my son to wake up.
Old Feb 7, 2009 | 12:55 PM
jbrew's Avatar
Sounds like there's more going on here really. - Cats are red because their on fire and burning up. You could even be in "Limp Mode" PCM isn't giving your injectors what they need. Caused from terrible maintenance. One problem lead to another and another like domino's. You need to go thru it now. Some of the fuel you are getting isn't combusting because there's nothing to light it lol. Raw and unburned, therefor, your O2's are fouled and cats are fuel soaked. IAT's don't really go bad to often, unless you break a wire. MAF is probably dirty as hell - Just one of the problems.
I have know idea why you not getting more codes ???? You should be.
I could be wrong to some extent - Hard to say without knowing the history and order of events. Idunno, something funny here
AIR INLET TEMPERATURE (AIT)
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
The IAT sensor is a temperature sensitive resistor (thermistor) connected to the internal resistor network in the Powertrain Control Module, the EECV, and it provides a output voltage inversely proportional to the intake air temperature. The PCM uses this input as a corrector for airflow calculations, to proportion the cold enrichment fuel flow and to modify spark advance.
Typical Malfunction Thresholds: Voltage <0.20V or Voltage >4.80 V
Old Feb 7, 2009 | 01:33 PM
jbrew's Avatar
I doubt it.
Old Feb 7, 2009 | 05:11 PM
jackedf150's Avatar
Well what should the multimeter be set on to test the coils, i put it 2000k ohms and it shoots up then comes back down to the number 5 and 6 and fluctuates. How does limp mode work. is there a way i can reset it?
Old Feb 7, 2009 | 05:42 PM
jbrew's Avatar
Why reset it? - You have to fix the problems first. She goes into Limp mode to protect your cats. I don't think it helped if that's the case.
I think you should take it in.
Old Feb 7, 2009 | 05:55 PM
tjk_in_cny's Avatar
What meter did you buy. If you can't post a pic, find the website of the name-brand you bought and post the web-site in 1 of your posts.
Like Brew said, you have to fix a few things 1st that are obvious repairs. Then you can do an erase on your DTC's including the pending DTC's with your friends Modis unit. Basically clears the PCM and resets the PCM to original factory parameter's so it has to re-learn the driving parameter's.
I think that came across right, if not Jbrew and a few others will give me a thrashing if it didn't.
