Cant read codes from OBII port.
Old Feb 6, 2009 | 08:08 AM
jackedf150's Avatar
I have a CEL and took it to 2 different locations to have them check it, they both say that i dont have any power to the port. What could be the problem, how else can I find the codes? And they both use the same code reader. Thanks
Old Feb 6, 2009 | 08:25 AM
F150NJ's Avatar
You didn't say which truck or year... but the problem is most likely a blown fuse. Check your owner's manual or Google or wherever to find the fuse location. A guess would be fuse #3 under the dash.
Old Feb 6, 2009 | 09:09 AM
jaymz's Avatar
Believe it is the same fuse as ciggy lighter. Check the lighter and if it doesn't work, there's your problem.
Old Feb 6, 2009 | 09:20 AM
jackedf150's Avatar
its a 2002 f150 and 1 of my cigerrete lifgters works the other power point does not.
Old Feb 6, 2009 | 03:02 PM
F150NJ's Avatar
Power port and OBDII connector are on the same fuse, separate from cigarette lighter, IIRC. Did you check fuse 3 under the dash?
Old Feb 6, 2009 | 04:21 PM
jackedf150's Avatar
got it fixed it was the fuse, thanks
Old Feb 6, 2009 | 05:04 PM
F150NJ's Avatar
Cool. I posted that before I read your other thread. Red hot cats!
