difference between lightning and regular...
Old Feb 3, 2009 | 06:54 PM
Stephen87's Avatar
what is the difference between a lightning and a regular 5.4l f150 as far as the engine(internal and external) is concerned.
and I know the lightning has a S/C I am just curious if the lightning has stronger internals or what because I was under the impression that all f150s were built with forged internals
Old Feb 3, 2009 | 08:29 PM
Buck50's Avatar
Forged Steel Crank
Forged alloy connecting rods
forged pistons(compression ratio to 8.4:1)
The Blower. Water to Air Intercooler
Transmission: 4 speed out of the Power-stroke Diesel
Suspension and Steering
upper and lower A-arms
SVT coil springs
SVT gas-charged shock absorbers
31mm solid stabilizer bar.
Front-end ride height lowered half an inch
9.75-inch solid axle
3.55:1 limited-slip rear end.
SVT-tuned gas-charged shock absorbers
Rear:
SVT five-leaf spring system
SVT 23mm solid stabilizer bar
Rear ride lowered 2.0 inches
The staggered right rear shock
Brakes
F-250 Super Duty truck ( 4.0 mm thicker then F-150) front:12.1in twin-piston calipers. Rear 13.1 inches.
Rims and Tires
The cast five-spoke aluminum-alloy wheels 18 x 9.5 inches.
Tires: Eagle F1-GS 295/45ZR18
Old Feb 3, 2009 | 09:32 PM
phil6608's Avatar
The only thing internally is the forged pistons and crank!
My stock 03 5.4 had a forged crank.
Lightning and regular 5.4 have the crappy rods in them.
Phil
Old Feb 3, 2009 | 10:59 PM
Stephen87's Avatar
ah I see the reason I am asking is because I want to do the whole 4.6 to 5.4 swap but from what I have been able to find I can get a regular 5.4l for about 400-800 and the lightning engine I cannot find it for less than 3000
So I was thinking about buying the regular 5.4l engine and then rebuild it with completly forged internals (buy a forged rotating kit) and then either do a twin turbo kit or a ken belle supercharger(but by the way it sounds the supercharger might be a easier option)
what do y'all think
Old Feb 3, 2009 | 11:00 PM
f150fella08's Avatar
Originally Posted by Buck50
Forged Steel Crank
SVT coil springs
Rear:
Brakes
Rims and Tires
wow
Old Feb 3, 2009 | 11:45 PM
Buck50's Avatar
Phil
Lucky Butt
Old Feb 4, 2009 | 01:28 AM
Gotts2BMe's Avatar
all 5.4's made between 97-01 had the forged crank. All 4v navigators had it. All lightnings/harleys got it as well. 02-04 2v's had a 50/50 shot of getting the forged crank or the cast one.
Old Feb 4, 2009 | 01:30 AM
Stephen87's Avatar
well I ran into a small problem I cannot for the life of me find a engine rotating kit for a 2003 f150 5.4l engine its like they only make rebuild kits for the 4.6l engine
so since the 2001 is the most recent that has the forged crank I might as well just get the 5.4l engine from that year.
Old Feb 4, 2009 | 05:30 AM
phil6608's Avatar
what do y'all think
The reason the L motor is so much more money is they are more in-demand and they are supercharged!
Phil
Old Feb 4, 2009 | 05:41 AM
phil6608's Avatar
Here ya go,,,hope I didn't forget anyone.
Have fun shopping.
http://store.summitracing.com/egnsea...=KeywordSearch
http://www.johnnylightningperf.com/s...php?cPath=2_14
http://www.lightningforceperformance...32_457_98.html
http://www.lethalperformance.com/99-...ngine-c-18_423
http://www.teamjdm.com/shop/index.php?cPath=11_5
Old Feb 4, 2009 | 11:30 AM
Stephen87's Avatar
Man thanks alot for those sites I might have to go with team jdm for the engine rebuild kit, and then summit for the crank and then buy a gaskets set/head bolts from a different place and then try and figure out what else I will need to finish that off.
well time to go and find a 5.4l engine and if I can find it cheap enough then I will put the money saved towards a kenne belle supercharger.
Old Jul 29, 2009 | 04:01 AM
stallyn1's Avatar
yeah thanks alot for those sites phil
Old Jul 29, 2009 | 11:52 AM
Veteran: Army
the '99-'00 Lightnings had the 3.55 rear gears, the '01-'04 Lightnings had 3.73 gears
Old Jul 29, 2009 | 12:26 PM
deerhunter7979's Avatar
^^^This is new info for me! How does a person KNOW if their engine has a forged crank? Where do I find it?
Old Jul 29, 2009 | 03:04 PM
scruffy's Avatar
Read through this: https://www.f150online.com/forums/v8...3-n-5-4-a.html
The third post has comparison pics, and they go on to show casting/forging numbers.
