Oxygen O2 Sensor
Google searching the meanings of those codes would have been more productive by far.
Specially if you don't shave those ears on the connectors off first. I haven't had one match the stock connectors.
Good morning to all, Looks like my check engine light is completely out. It doesn't come on when I turn the ignition. That would explain why my check engine light is not coming on. I will replacing the bulb this week-end any how what about the 02 sensors. What else is causing the malfunction? I replaced them about 4 months ago and cleared all the codes. By the next day when I travel to any destination the same error codes came up. Could it be the computer or what.
Do you have remote start locks added on? If so remove the unit from the system and reset ecm unit. I have had trouble on several diffrent vechicles because of the remorts that are added on, not fractory, Ecm will give bad reading because it cannot reconise the addon. I have had to cut most all out of system, and all worked fine after that. Bad addon unit can cause many problems that aren;t there.
Yep, you got it. When the truck was made the ECM was not programed for it unless it is factorie. Therefore the ECM will not reconise it. The add on ties into the starting system as well as the locks and other systems. If the addon goes bad it screws up the ECM and causes it to send wrong codes.
Maybe that's why, they were having problems with the module/programming capability with the PCM, sort of like you said. I like it this way anyway.
Posted by: rdvarona
On: 02-09-2009 10:40 AM
good morning,
I do have an after market remote start lock. I will unplug it then reset the ECM. Do I connect the remote start after I reset the ECM ???
NO do not plug the remote start back in untill you have driven the unit several miles to see if it was causing your trouble. If the light stays off that was the probem. If the light comes back on the ECM will tell you what is realy wrong with unit. Just fix that then plug the remote back in if you wish to do so. Best of Luck
good morning,
Good luck
Help, Please ... I am still getting the same trouble codes
P0161 Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P0155 Oxygen 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0141 Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
I disconnected the after market remote lock and it is still disconnected. I reset the system last night and when I got to work this morning I connected the code scanner and got the same codes again. What else can I do ???
