I have a dumb ?
Old Jan 27, 2009 | 09:00 PM
homer1972's Avatar
I have a dumb ?
Is there an easy way to get the starter out? My 98 won't turn over, Battery checked out, but no life from the starter. Thanks in advance
Old Jan 27, 2009 | 10:07 PM
masterbeatty's Avatar
did you check the starter cylinoid? i cant spell but i think ya get what im say.
Old Jan 27, 2009 | 10:43 PM
chiefFX4's Avatar
yea, most likely cause is the SOLENOID (sorry, had to be a ****).
take a screw driver and stick it on the starter on the bolts where the black wire and red wire are connected. if the truck turns over then youve discovered your problem.
if nothing happens then you need a new starter.
Old Jan 27, 2009 | 10:59 PM
homer1972's Avatar
Haven't tried that yet, I'm getting snow in my "garage". I read that there is a relay on the firewall under the battery cover, is this a problem area also if there is one? I was trying to get a socket on the bolts and I couldn't get any ones I have on hand on the bolts. Go figure.
Old Jan 27, 2009 | 11:05 PM
shifty_85's Avatar
yeah these starters are a blast to take in and out just have Jbrew come over he takes his out because he gets bored. the top bolt is a PITA did you already try the screw driver across the solenoid on the firewall? ill take a picture of how to do it. but im guessin its the starter. ive had mine out a few times it is a pita good luck bud.
Old Jan 27, 2009 | 11:09 PM
tjk_in_cny's Avatar
Just changed mine out a few weeks ago. The easiest way is to remove the passanger side tire so you can access 2 of the bolts pretty easily. There will be one bolt at the 12 o'clock position and one bolt at the 9 o'oclock position.
The last one I remove is from the bottom of the starter.
You will need at least a 6'' + 3" extensions to get easy access to the bolt's in the 9 & 12 o'clock position's.
Complete job is about 2 hours, lifting truck, removing tire, removing starter, installing new starter, tire on, lowering truck, cleaning tools, throwing the junk starter in the neighbor's lawn, and driving again.
Unless you run into a problem, not a bad job, really.
I do not recommend a rebuilt starter. A new starter for a decent name brand is usually only an extra $20.00.
Good Luck with it.
TJKinCNY
ps: you need to use metric sockets !
Old Jan 27, 2009 | 11:19 PM
tjk_in_cny's Avatar
It's not under a battery cover, it's under your starter relay/fuse cover.
You may want to check for voltage on the 2 main RED lines with ignition key on/forward. Check on both sides of the mega fuses and at your starter relay.
The starter relay is positioned to the left of the mega fuses. If your lucky, Jbrew will read this and post pic's for you. He just had to for another member last week. If you do a search or go to Jbrews photo album's, you will find the pic's there.
Old Jan 27, 2009 | 11:22 PM
tjk_in_cny's Avatar
Oh ye, almost forgot, welcome to the sight.
Jbrew is the guy who loves tearing his truck apart and putting it back together and he has alot of pictures to help people out.
I am the "Google" guy, right Brew.
Old Jan 27, 2009 | 11:31 PM
jbrew's Avatar
I am the "Google" guy right Brew.
Yep! ~ And the guy who handles the Dumb Question threads I see
Good job!
Old Jan 27, 2009 | 11:54 PM
tjk_in_cny's Avatar
Good job!
Jerk Just for that, I am going to take pic's of my wifes Scion TC fender liners for you.
Old Jan 28, 2009 | 02:17 AM
jbrew's Avatar
Your wifes what ?
Is she hot?
Old Jan 28, 2009 | 08:07 AM
Camarothatcould's Avatar
jbrew is my personnal hero on here. . .
Old Jan 28, 2009 | 08:15 AM
tjk_in_cny's Avatar
Old Jan 28, 2009 | 08:24 AM
tjk_in_cny's Avatar
Your wifes what ?
Is she hot?
I didn't say I was going to show you what is under the hood, just the fenderliners .
Yep, she went car shopping a couple years ago and fell in love with the Toyota, Scion TC. In other words, the driving fish bowl. That car has more glass in it than any car (out of the factory) that I have ever seen. The entire top of the car from bottom of the windshield to the bottom of the rear window is all glass, and of course all the metal supports. Great car except I am 5'11" and there is no head room.
Old Jan 28, 2009 | 09:34 AM
JMC's Avatar
JMC
25 Year Member
Before you remove the starter check the cables going to the starter for corrosion. Theses trucks are known for corrosion wicking up the wire and causing a problem. Specially at the starter end.
