Code P2072?
Old Jan 24, 2009 | 11:15 PM
LovetheTide's Avatar
Code P2072?
I was messing with my Gryphon and found I had Code P2072 thrown. It says "Throttle actuator control (TAC) system- ice breakage."
Can anyone tell me what this means and what I need to do.
Old Jan 25, 2009 | 03:14 AM
jbrew's Avatar
Well , I don't know that much about it - I've heard it coming up before in later model cars and some needed a re-calibration. I'm pretty sure it has to be done via laptop w/the latest calibration,- if I'm recalling it right. And, it's probably not just the car-lines that's effected. I haven't heard of the 150's with this problem.
Did you try dumping the DTC and/re-booting ? I would definitely give that a try first. Maybe the PCM got a little buggy at some point and locked on that one.
Old Jan 25, 2009 | 11:54 AM
This is another language to me.
How do I go about re-booting? I know how to clear the code on the Gryphon but not re-boot.
Old Jan 25, 2009 | 12:16 PM
jbrew's Avatar
Re- booting is clearing the KAM (Keep Alive Memory) - Computer relearns thru it's adaptive strategies. Sorta of like re-booting your home computer when sh^t stops working properly.
With a tuner, you return to stock, then disconnect the battery for about 15-20 minutes.
Old Jan 25, 2009 | 06:12 PM
jbrew's Avatar
If it comes back - A call to Bill or Corey might help. The Gryphon should have that capability to see what monitors have run after reboot. I would keep the stock setting until at least all have run but the EVAP. Sometimes the EVAP monitor takes time. Have at least 3/4 tank of petrol when doing this, you'll have better luck.
Was your CEL on before the code recognized by you ? Or was it just in the tuners scan ?
If just in the tuner scan, then I would call the PHP. That probably should have been first , sorry ..
Old Jan 25, 2009 | 08:36 PM
I returned to stock settings then went back the towing tune aswell as clear the code. Since then I put on 100 miles and it hasn't come back up yet, if it does I'll cal PHP and figure this out.
