2000 F150 XLT Fuel pump?
Any thoughts i was driving down the road at 50mph and the engine died i pulled over tried to start it it sounded like it wanted to start but wouldnt? what couldit be my thought was a fuel pump?
)By the way, did you open up your access door where you fuel it up and then pull the gas cap and listen to see if the fuel pump is running. If there is not alot of noise (prefer no noise), you should be able to here the pump engage with key forward but engine not started. Again, no manuals handy, but you can check your fuel pump relay by switching it out with a matched one that is in your "under hood fuse panel or relay panel". Someone on here just posted which ones can be switched out. If you still have your glove-box Ford manual, it will show you which one is your fuel pump relay. You can match the info and numbers with another one and temporarly switch them out to remove the possibility of a bad relay.
In order:
(1) can you hear fuel pump engage at gas tank fill opening. If you can hear it engage, change fuel filter and then check fuel pressure. If not, go to step 2
(2) check for bad relay, if relay is ok then you will have to drop the tank and pull the fuel pump. Been there and done it, not to bad of a job. My fuel pump was fine, tank was leaking.
This will get you started. There are other members who will add more info I'm sure.
Good luck with it.
TJKinCNY
