Randomly running like crap
Alright looked and looked and looked. No sparks arching anywhere.
So in the next day or two ill try to complete:
Fuel pressure test and replace spark plugs, i can load the spark plug boots with dielectric grease again too. and go from there.
Wacko - what would be a good way to perform a resistance test?
You may have an internal seperation inside a plug wire that a small amount of electricity can jump, but under a load the wire is not capable of supporting more electricity for more spark. This is something that you can easily check with a DVOM and will save you from replacing perfectly good parts. As far as spark plugs cheap and easy to replace and rule out!
