What to look for...plugs
Old Dec 1, 2008 | 12:05 PM
evomoose's Avatar
Having read many of the threads on here relating to using different plugs (and that Motorcaft is the way to go) but when the 'other' plugs go down can you actually see the problem? ie ....are the electrodes worn or damaged? Or is it an internal failing?? Cheers
Old Dec 1, 2008 | 02:29 PM
Matts ford's Avatar
this shows everything for the 4.6 and 5.4 2v engines.
https://www.f150online.com/forums/en...gs-can-do.html
dont worry about the valve noone knows for sure what happened there. just look at the plug.
ngk, denso and motorcraft are the best for the modular engines.
Old Dec 1, 2008 | 05:47 PM
evomoose's Avatar
OK, saw that pic, but is that the norm for plugs that fail?
Old Dec 1, 2008 | 05:49 PM
Not sure there is a norm. They burn off slowly, they fragment as that one did, or the porcelain might crack. Some just never run correctly. What year and what engine?
Old Dec 2, 2008 | 01:57 PM
evomoose's Avatar
An 01 with 5.4
I'm only wondering so that if I have a problem I know what to look for.
Cheers
Old Dec 2, 2008 | 02:11 PM
Wild Turkey's Avatar
Plugs
Just do not use Champion plugs! they will not last in an f-150. Motorcraft is the way to go! They are motorcraft/ford for a reason!
