spark plugs
Old Nov 26, 2008 | 11:53 PM
MI02SVT's Avatar
spark plugs
has anyone heard about these new pulse plugs well they came out a little while ago but there supposed to be really good they gave a stock 350z 11 more hp just by changin them out has anyone tried them at all just wonderin
Old Nov 26, 2008 | 11:58 PM
maxturbo's Avatar
Did you see any dyno sheets? Cause 11 hp from just swapping plugs is almost unheard of. The most I've ever seen was 2hp from swapping plugs. There was a racing mag that tested a bunch of plugs to see if any had any gains. And the only one was the iridium plugs gained 2hp. And each set of plugs they tested they backed it up with real dyno sheets.
Old Nov 27, 2008 | 12:23 AM
MI02SVT's Avatar
heres the site i had one buddy put them in his blazer and he said he noticed a big difference after he did i was just wonderin if anyone else heard of them or tried them out and noticed anything http://www.pulstar.com/index.html
Old Nov 28, 2008 | 12:33 PM
Are they even available for your truck? You didn't list your year and engine.
Old Nov 28, 2008 | 05:52 PM
jbrew's Avatar
You covered it - Good info !!
Old Nov 28, 2008 | 05:59 PM
jbrew's Avatar
I've read up on Pulstar awhile ago and back then, they had plugs avalible for 5.4 models. Back then they were testing these plugs in imports (about a year ago) - Tests concluded no HP gains but they did increase mileage.
Believe me, if these plugs were of great benefit to us, we sure as hell would know it by now..
Go with the Denso 16's if you want the best IMO.
Old Nov 29, 2008 | 11:24 PM
maxturbo's Avatar
My advise would be to stick with the ford plugs. After over 20 years working on these cars n trucks and replacing tons of aftermarket plugs due to ignition problems. Just cause it saved the customer a few bucks. But in the long run you'll be paying more. Cause you'll be bringing it to a dealer where a guy like me will be swapping those brand new plugs u put in, for some motorcraft plugs and ur problem will b solved.
