throttle doesnt work?????? 2007
Old Oct 29, 2008 | 04:18 PM
BakerF150's Avatar
07 F150... truck runs and drives fine but when you push the gas it does nothing. it will idle all over the place. Do these trucks have a cable or no. Any ideas on what this could be?
Old Oct 29, 2008 | 04:20 PM
kingfish51's Avatar
No they have no cable. It is a computer controlled throttle. As it is under warranty, take it in.
Old Oct 29, 2008 | 04:22 PM
Matts ford's Avatar
its electronic controlled. do you have a code P0506? or any codes at all? some people here have similar problems and clean the throttle PLATE(not covered under warranty so its a DIY), not the whole throttle body. do you have any aftermarket air filter or induction? how many miles? motor?
i'd take it in to the dealer. and have the latest program installed if it hasnt already.
Old Oct 29, 2008 | 04:29 PM
BakerF150's Avatar
yeah... ill be honest. the lower part of the truck got wet so im thinking it might have got wet. 30,000 miles. where is this module or sensor we are talking about? i imagine under the dash or maybe low outside? thanks fellas.
Old Oct 29, 2008 | 04:36 PM
Matts ford's Avatar
the throttle body is under the hood on top of the engine under the airbox. the pcm is in the drivers kick panel i think. i dought its the pcm. you need to take it to the dealer if its under warranty.
Old Oct 29, 2008 | 04:41 PM
BakerF150's Avatar
its not under warranty. pcm is the entire computer right? it runs and idles around the lot so does that narrow it down at all?
Old Oct 29, 2008 | 04:42 PM
BakerF150's Avatar
when i say wet i mean it sat in water... lol. didnt run it in the water tho.
Old Oct 29, 2008 | 04:44 PM
Matts ford's Avatar
yup it means the pcm is working otherwise it wouldnt run at all. see if you can start it with the pedal to the floor(it should not start). if it does its gonna require some diagnosing.
Old Oct 29, 2008 | 04:48 PM
BakerF150's Avatar
ok ill check and let you know. thanks bro for the info.
Old Oct 29, 2008 | 04:51 PM
Matts ford's Avatar
why is it not under warranty? is it because the water?
Old Oct 29, 2008 | 05:06 PM
BakerF150's Avatar
yeah.
Old Oct 29, 2008 | 05:19 PM
06yz250f's Avatar
the dealership doesn't know if your truck was in water unless it was reported on insurance
Old Nov 3, 2008 | 01:13 PM
BakerF150's Avatar
When i push the pedal to the floor and then try to crank it, it doesnt crank. What does that mean to whoever said check that?
Old Nov 3, 2008 | 07:03 PM
Matts ford's Avatar
it means somethings wrong. it should still crank but it shouldnt start. it disables the fuel system with the throttle all the way open.
Old Nov 3, 2008 | 09:36 PM
BakerF150's Avatar
No.... it was turning over but never started. I eventually got the pedal working and all and drove it to the dealership to fix it up right.
