Block heater
Old Oct 28, 2008 | 07:15 PM
Camarothatcould's Avatar
Block heater
The 5.4 I bought does not have an engine block heater. I do not want to re-use the one that was on the 4.6, it was weak and barely kept the engine from freezing, so I would like a more powerful one. Any suggestions on where to buy from?
Old Oct 28, 2008 | 07:48 PM
Blown F-150's Avatar
I put a napa one in my Ranger and it was awesome! Literally Minus 45c and the old girl would still crank over and fire up! You could here it work.
Old Oct 28, 2008 | 08:24 PM
How much did you pay. And are we 1 1/2 inch freeze plugs?
Old Oct 29, 2008 | 03:00 PM
I've always liked the circulating type heater over the freeze plug heaters. They tee into the heater hoses.
Old Oct 29, 2008 | 06:32 PM
Price and where?
Old Oct 29, 2008 | 10:23 PM
You should be able to get a circulating one from pretty much any auto place. The block one I bought was around $25. I agree the circulating one is probably a better buy, especially if the truck doesn't have one to begin with. I don't think it could be much more than $40. check www.summitracing.com
Old Oct 30, 2008 | 01:17 AM
NAPA has em for $30. Doesnt get to the single digits here barely, circulating one would be nice, but its $70. . .
thanks guys
Old Oct 30, 2008 | 12:07 PM
jbrew's Avatar
Huh, never had or needed one of those, but it's never outside for long in the winter either. Well , unless we get a bunch of the white stuff
Old Oct 30, 2008 | 12:27 PM
I know it isn't the best for it, but my truck starts reliably @ -30c with out being plugged in. I think it was the year before last, but in Winnipeg we had 32 or 33 days of solid temps below -25c, that sucked!
Old Oct 30, 2008 | 04:07 PM
Gotts2BMe's Avatar
Yeah my truck starts real well when it is in those -30 degree days without being plugged in. I have a 1200 amp battery, 1000 CCA, its a beast of battery. I wouldn't plug it in above 0 degrees Fahrenheit, and thats what it says in the manual as well. If you are gung hoe on having a block heater look into the ones that go on the bottom of the oil pan, they work AMAZING and only about 2 mm thick.
Old Oct 30, 2008 | 06:32 PM
I run a 1000 CCA battery as well, not really needed not that I'm in Vancouver.
