Can I replace a 4.6L with a 5.4L in my 98 F150
I have a super cab 98 4x4 F150 that has a blown head gasket and I'm considering putting a whole new engine in from the juck yard ...would a 5.4L fit? and would the wiring match up to whats on my firewall? Has anyone done this before and was it hard?? thanks..
a 5.4 will bolt right in, you'll have to get a custom tune done though to run the larger displacement.
if you can find a complete engine with wiring harness it'l be a direct plug-N-play swap and the perfect time to toss on long tube headers, mild cams and larger injectors.
Hey. Talk to JMC and JBREW, i am in the starting of putting a 2002 5.4 in my 1999 4.6...Its gonna be well worth it. I got a bunch of add ones aswell, might as well do it while the engines out of the truck sitting in your garage.
Yes you can do it. yes there are other bits and pieces to work out: exhaust downpipes lengthened, add a threaded hole for a coolant sensor,maybe extend a couple wires. there a re a few write ups on this here, use the search feature. not hard to do at all, as i have done it and added comp cams to it while it was out of the truck.
No vids or audio. lope on the cams is definately better than stock, makes it sound like a different engine altogether. the cams were comp 102500 xe262ah pi specific cams, check the website for specs. I have a 02 navi motor that i am putting together and plan to order the same series in dohc fo that to put in my truck. Don't know about hp gains as it wasn't dyno'd before and after, but with the weight and speed in the 1/8 mile it looks to be pushing around 280 to 290hp.
