Cold start problem
Old Oct 19, 2008 | 08:25 PM
piletz's Avatar
Cold start problem
I have a 2001 5.4 Triton and it takes about 20 times to get it started. I just replaced the fuel pump and the problem is exactly the same. I have been told it maybe the CHT sensor. ANY SUGGESTIONS? Thanks!
Old Oct 19, 2008 | 09:28 PM
Have you checked for DTC's with a code reader? Is the CEL on?
(CEL = check engine light)
(DTC = diagnostic trouble code)
Old Oct 20, 2008 | 09:44 AM
06 So Comfort's Avatar
You could have a bad fuel pressure regulator - not holding pressure after the pump stops.
Old Oct 20, 2008 | 06:46 PM
chug4real's Avatar
Well on my 01 screw whenever it was cold out usually in the mornings since I live in Florida it doesn't tend to get to cold but I replaced the IAC and the problem was fixed. You might want to give it a look and clean it or replace it.
Old Oct 21, 2008 | 05:48 PM
piletz's Avatar
There is no check engine light on?
