spark plug wrench
Any standard 5/8" socket and extension/universal will work.
Yup, on the old 2-valve 4.6 & 5.4, just any ole 5/8" socket and a 6" extension will work.
Word of warning though...
The last time I changed plugs on my folks' 97 TownCar with the 4.6L I was using a new socket. The rubber insert was gripping the plugs so tight I kept pulling the socket off of the extension...leaving it down in that #*%& hole on every plug! I eventually got PO'd enough that I just tacked the socket & extension together with the welder. Now I've got a homemade "long" socket just for those engines.
Bindernut, That's exactly what I was thinking about doing if there wasn't a one piece socket/extension available, welding it together. I ran into the same problem with extension with the spring loaded ball bearing. What a pain!!
jethat ---
Harbor freight online did have a 5 1/2" long 5/8" spark plug socket, Thanks. Inexpensive too! Have you used this socket? Actually the last plug on the right bank is the pain for me on the 4.6
No I havent used it YET. I'm gonna buy it and use it on my van in the next week or so.
Craftsman has a locking extention that I have and have used for removing plugs. It works good.
