5.4L 3V Catastrophic engine failure
Old Oct 14, 2008 | 06:07 PM
JTE3097's Avatar
My 2004 F-150 with 95XXX miles died last week. Was driving home from work when I had sudden loss of power and a CLANGING noise coming from the motor.
I got the truck home, pulled valve covers and discovered broken rocker and no valve on cylinder 3. Started the process of pulling the motor, and dropped the oil pan and could see the bottom of the head through the hole in the piston in cylinder 3.... lots of metal in pan.
Anyway, from what I can tell the timing belt tensioner on that side failed, allowed the chain to become QUITE loose, and the motor went out of time and caused a valve to contact a piston. All in all, pretty bad damage.
Even more scary, there where no warning signs, and the truck was maintained religiously by a mechanic (me).
However, I picked up a BRAND NEW 08 5.4L 3v for 1700 bucks and have it in the truck already. Just gotta hook up wiring and hoses. Hopefully I get more than 95XXX miles this time.
Old Oct 14, 2008 | 06:15 PM
F150+Bronco=ME's Avatar
that sucks, at least you got a good deal on a new engine though
Matts ford's Avatar
what kind of oil did you use. the chain tensioner is hyd. and works from oil pressure. and what do you mean by you could see the bottom of the head? did it throw out the whole piston or something? what exactly could you see that happened?
Old Oct 14, 2008 | 06:44 PM
JTE3097's Avatar
naa, there's a yellow piece of plastic that the timing chain runs along side of, that was not there on the offending side of the motor. This caused the chain to be very loose.
About the piston, I meant I could see through the large hole in the piston up to the head. I was looking from the oilpan up past the crank.
Always just used motorcraft 5w20 and a motorcraft filter.
Old Oct 14, 2008 | 06:47 PM
noblem's Avatar
tough luck man. is this a common occurence in the newer motors do you know?
Old Oct 14, 2008 | 06:49 PM
4.6 Punisher's Avatar
Sorry for your loss.
Now that we got that out of the way, got any pics?
Old Oct 14, 2008 | 06:50 PM
JTE3097's Avatar
never heard of it. I'm convinced it's an isolated incident related to the failure of a single part. *im hoping*
Old Oct 14, 2008 | 06:53 PM
JTE3097's Avatar
carnage pics forthcoming
Sweet!
Old Oct 14, 2008 | 07:01 PM
shoulda gotten a 4.6
Old Oct 14, 2008 | 09:33 PM
built54's Avatar
then he wouldnt of had the power to blow it up.... good point!
Old Oct 14, 2008 | 09:37 PM
homerpete's Avatar
I could just see that happening to mine lol, hope it does not.
