Rough Idle and Smoke
Old Oct 16, 2008 | 03:37 PM
nick16's Avatar
it just needs to be driven. im 16 and had a 2000 4.2L v6 f-150 and mind was left for about a whole winter with out beaing started once i drove it, it was fine. when i did the oil change i used some lucas oil substitue stuff i recomend that its amazing and works great it will help clear up the smoke faster but mainly it just needs to be driven and it will be fine
Old Oct 16, 2008 | 07:32 PM
pu2ded0's Avatar
new fuel and fuel filter today. no change. will change plugs and cops and clean throttle body next. hope to be on the road soon to blow it out.
Old Oct 16, 2008 | 07:42 PM
Matts ford's Avatar
does it have tags? if so then just drive it for a little bit and see what happens. if not tagged then do you have land to drive it on? i really think its just sat so long that it needs to be ran and driven. if theres no change i'd say try the plugs, the cop's, and cleaning the tb usually does help with idling. that along with cleaning the maf sensor.
Old Oct 16, 2008 | 08:21 PM
pu2ded0's Avatar
no tags, was waiting til i get it running better. prbably could find somewhere to run it around on. what and where is the maf sensor? acronyms are killing me.
Old Oct 17, 2008 | 03:04 AM
jbrew's Avatar
Check your PCV valve and system well. Absolutely do not put more than 6 quarts of oil in the crankcase. #1 reason for gasket failure.
Change the oil if it was sitting for more than 6 months.
Monitor your coolant.
Here's your MAF sensor info -
http://www.fordf150.net/howto/clean-...low-sensor.php
Old Oct 20, 2008 | 07:04 PM
pu2ded0's Avatar
already did oil change, will do pcv, plugs, coils and throttle body clean now. anyone know what plugs to use (motocraft)?
Old Oct 20, 2008 | 07:59 PM
jbrew's Avatar
Yea , MotorCraft. The Fine-wires are sweet.
Old Oct 21, 2008 | 12:43 AM
pu2ded0's Avatar
Part # please?
Old Oct 21, 2008 | 02:38 AM
jbrew's Avatar
Part # please?
1997 Ford F-150 - Motorcraft Spark Plug
Our Price: $16.58
Part Number: MISP459 ~ MFR#: SP459
"SPARK PLUG -- High Quality, Original Equipment Replacement Part, Direct Fit"
Fit Note: ".054 Gap, Finewire".
This Product Fits the Following Vehicles: Live Help
1997 Ford F-150
1997: 8Cyl 5.4L "Gas, Fuel Injected, VIN L" Base
1997: 8Cyl 5.4L "Gas, Fuel Injected, VIN L" Lariat
1997: 8Cyl 5.4L "Gas, Fuel Injected, VIN L" XL
1997: 8Cyl 5.4L "Gas, Fuel Injected, VIN L" XLT
Availability
In Stock - FREE shipping on orders above $50
Low price guarantee
__________________________________________________ ____
Old Oct 21, 2008 | 01:02 PM
I hope that's the price for a 4-pack - rockauto.com sells SP459's for $4.53 each.
Old Oct 21, 2008 | 02:30 PM
BigBlue5.4's Avatar
I had the exact same thing happen to me. I was losing coolant like crazy and turns out that I have a blown head gasket.
Old Oct 26, 2008 | 10:33 PM
pu2ded0's Avatar
what color was your smoke? did it get worse as the engine got warmer?
Old Oct 26, 2008 | 10:58 PM
jbrew's Avatar
Yea that's for a 4 pack. - http://www.autopartswarehouse.com/?a...ID=110329&cj=1
I use those guys or Rock - whoever is cheaper. APW is usually cheaper w/free shipping over $50. PLUS They carry the right stuff, like Rock.
Rocks got an ebay store (Think it's called "Rockaholics" ) that has some really good deals @ times.
