Spark plug tool
Old Oct 9, 2008 | 11:08 AM
Roodoo2's Avatar
Spark plug tool
Ok I hope this is not a repost
Aftermarket has the tool now for removing plugs from triton 3v motors
Lisle #65600 "comes with porcelain pusher and a tapered left hand thread remover for removing the broken plug without leaving the porcelain in the cylinder. Pusher is designed to press the piece without breaking it farther into the plug tip. This provides a place for the LH thread removing tool to grip the SS plug tip so it can be pulled. "
Old Oct 9, 2008 | 12:42 PM
Yup, it's a repost. Still good to know.
Old Dec 4, 2008 | 09:21 AM
Pacey's Avatar
I just had 4 plugs break off while changing them in my 2004. The porcelain was broke off in all of them. I ordered the Lisle Tool and it worked great! I would highly recommend this tool.
Old Dec 10, 2008 | 01:28 PM
cdn2usa's Avatar
Where do you purchase the Lisle # 65600 tool and how much is it?
Old Dec 10, 2008 | 01:31 PM
jbrew's Avatar
I would try eBay or here -
http://www.denlorstools.com/home/dt1...65600_alt.html
Old Dec 15, 2008 | 07:10 AM
Pacey's Avatar
I found mine on Amazon.com from a company called Etooldirect.com
John
Old Dec 15, 2008 | 11:46 AM
F150FXOnline's Avatar
Kinda screwed up still. Just seeing this for the first time a fix that is. You use the tool only when its broke off in the head and can only use it one time. So if 3 get broke off in the head its going to cost you $225.00 just for the tool . ( I think the link above said $75.00 each. Then to top it off people are happy about it. Kinda sucks at the sametime your happy? Does that make since!?!?!?
Old Dec 15, 2008 | 11:53 AM
azmidget91's Avatar
the rotunda tool has parts that can only be used once not the lisle, which is what is being discussed
Old Dec 15, 2008 | 12:07 PM
Thank You sir! I mis read the link above on the tool. It was explaining the new tool being the lisle which you can use more then one time. The rotunda tool was the one you can only use one time.
This is great news for sure!!
Old Dec 16, 2008 | 03:33 AM
code58's Avatar
F150FXOnline- It's the ceramic extractor you can only use one time because it gets glued into the hole in the ceramic. The rest of the kit can be used repeatedly. I like the idea of the Lisle a lot better because you don't have to glue anything in unless the ceramic is broken off too high. Plus it's a whole lot cheaper than the Rotunda. The Lisle is the most heads up design yet in my opinion.
