HELP! very weird thing happened today....
Old Oct 8, 2008 | 09:12 AM
Sunshine B's Avatar
While i was driving my car wasnt shifting well and the engine was making weird sounds every time id push the throttle the car wouldnt even move well and make a weird noise.. it wouldnt shift until after i pushed the throttle a couple of times it would hardly even move.. scary.. whats wrong can anyone please help me urgently? ..
thanks
ps i have edge and a volant intake installed+ 35" wheels + 3.73 gear ratios/5.4 v8
Old Oct 8, 2008 | 09:20 AM
jethat's Avatar
Pretty vauge there.. What engine? did your check engine light come on? could be several things. Getting cold could be the fuel filter is cloged. You'd get that in the morning gas is thicker when its cold and it will make your fuel system not work well when its cold. thats my guess..
Old Oct 8, 2008 | 09:23 AM
thanks
Just with that description, sounds like the transmission. I would return it to stock if it's still under warranty, and get it to the dealer.
P.S. I assume you returned it to stock and it does the same?
Old Oct 8, 2008 | 10:25 AM
Sunshine B's Avatar
nah not on warranty.. 60,000km atm ,i turned the edge to stock and still does the same.. but im gona take it to the dealer in abit.. im not sure whats wrong really.. i hope the gear isnt broken or something bad
Old Oct 8, 2008 | 12:56 PM
jbrew's Avatar
You need to follow thru with your answers. Address questions for you posted above by other members of this site. ~ That would be a big help on your part. if your not understanding anything asked of you - just say so
Old Oct 13, 2008 | 11:27 PM
Sunshine B's Avatar
i took my f150 to the service ..
thats what they wrote on my cash sale invoice..
Transmission shifting not prop
need to over hauling transmission
need to remove engine after dismantling
parts estimation will be given
gear lever assy need to change
Customer Information:
1.Diagnosed transmission shifting with WDS/IDS test. performed
fluid line pressure test . found fluid burnt. roadtest not moving forward & reverse, its need overhaul and gear lever indicator
Old Oct 13, 2008 | 11:32 PM
Silver FX4's Avatar
Ouch what the hell caused that??
Old Oct 13, 2008 | 11:42 PM
Sunshine B's Avatar
i have no idea.. any ideas?
my mileage is at 60,547 <<< Km's not miles
Old Oct 14, 2008 | 12:26 AM
pos racing's Avatar
no codes cmdtc's?was the eng light or wrench light on?if the pcm sees a fault with the throttlebody or overtemp will go into safe mode on 04-08 f150,there was a reflash for this.
Old Oct 14, 2008 | 12:29 AM
when is the last time you did a trans flush?
Old Oct 14, 2008 | 12:30 AM
Sunshine B's Avatar
i think i didnt see any light on .. mine is 2005
Old Oct 14, 2008 | 12:31 AM
Sunshine B's Avatar
"when is the last time you did a trans flush?"
59,500ish KM/s
But i havent done it for a long time before that
Old Oct 14, 2008 | 01:33 AM
Sunshine B's Avatar
maybe thats why it happened?.. should i do it more often?
(damn i miss driving my truck :S )
Old Oct 14, 2008 | 02:05 PM
pos racing's Avatar
did this concern start after the fluid flush and filter at 59000km?if so they may not have seated filter inlet to pump(have seen this happen)
Old Oct 16, 2008 | 11:12 AM
Sunshine B's Avatar
i fixed it today and they said that the both first 2 gear clutches were burnt or something like that.. i have no idea.. im a car noob
