CEL on with code, Needhelp
Old Oct 6, 2008 | 01:05 PM
mw3538's Avatar
engine stalled out twice 4 days apart. CEL is on now and had the code pulled. Shows a P2104 - TAC system forced idle. Please can someone help me with this. I have a 06' SCREW, 5.3L
Thanks.
Old Oct 6, 2008 | 02:11 PM
Matts ford's Avatar
never seen that code and cant find it at all. i'd say take it to the dealer if its still under warranthy.
Old Oct 6, 2008 | 02:34 PM
mw3538's Avatar
Out of warranty. How long is the power train warranty. I am sitting at 52,700
Old Oct 6, 2008 | 04:20 PM
TAC = Throttle Actuator Control. That's the electronic "fly by wire" throttle control. Replaces the throttle cable.
Old Oct 6, 2008 | 05:17 PM
mw3538's Avatar
So it needs to be replaced? How expensive of a repair for this? J/W as I can do most work myself and would like to do this if I can. I assume this is not covered by the extended powertrain warranty that is standard?
Old Oct 6, 2008 | 08:56 PM
It doesn't necessarily need to be replaced - it needs to be troubleshot. I was simply telling you what the "TAC" was. Check with your dealer on the warranty possibility.
It's telling you that something caused the TAC to go into a "forced idle" mode.
Old Oct 6, 2008 | 10:44 PM
mw3538's Avatar
Thanks for all your help. One last question. I have a air raid on the truck, will this void a warranty if it's covered?
Old Oct 6, 2008 | 11:31 PM
The Air Raid might be a contributing cause of this problem. I'd put it back stock.
Old Oct 6, 2008 | 11:32 PM
Matts ford's Avatar
air raid air induction or tb spacer? either way it shouldnt but its not helping any unless your truck is tuned.
Old Oct 8, 2008 | 04:49 PM
mw3538's Avatar
P2104
Have had the air raid on for over 30K with no problems. J/W if I should go back to stock before I take it to the dealer?
Old Oct 8, 2008 | 05:14 PM
pos racing's Avatar
take it to your nearest dealer,there was a tsb for a reflash on pcm,also a common concern was harness chafing on intake stud.
