Tapping / Knocking sound
Old Sep 30, 2008 | 08:25 AM
moflair's Avatar
Question Tapping / Knocking sound
I have a 2000 f150 w/218000 mi on it leaving work yesterday it started making this tapping/knocking sound and it felt like it was not getting enough gas. I had to constantly give it gas to keep it running, by the time I got home the sound was even louder. Had a mechanic listen to the sound he said it sounds like a rocker arm problem but couldn't say for sure. The earliest they said they could look at it is this thrusday. It seems to shift through all the gears with no problem but boy does the truck shake and sputter any thoughts. I really need to go back to work.
Old Sep 30, 2008 | 11:48 PM
Park it till they can look at it and rent or borrow a car. The more you drive it like that, the more likely you are damaging it worse by the minute.
Old Oct 1, 2008 | 02:11 AM
LastSplash's Avatar
Possible spark plug ejection?
Old Oct 1, 2008 | 02:11 PM
One loose plug shouldn't cause it to run that rough, but it wouldn't be a bad idea to check them.
Old Oct 1, 2008 | 11:34 PM
LastSplash's Avatar
Not a loose plug some people have had the threads in the head fail and the plug blows out.
Old Oct 2, 2008 | 01:30 AM
Right, but it makes noises before it blows.
