Help
Old Sep 29, 2008 | 04:22 PM
slomo_01's Avatar
Question Help
So i just(about a month ago) replaced both forward O2 sensors(had a light). I just got another light, this time the code is mixture to lean. What are some causes of this(could it be anything with the cat, or my computer). Saturday My wife and I were in town and I was waiting for her in a parking lot, and the engine started to idle really low and started to sound like I had a big cam in the engine. Could anybody help me out with this? Thanks Scotty
Old Sep 29, 2008 | 04:42 PM
Matts ford's Avatar
vacuum leak? check the pcv elbo right on the throttle body.
Old Sep 29, 2008 | 04:52 PM
Matts ford's Avatar
the pcv elbo should be on the back of your intake. if its sucked shut or rotted with a hole(s) then its no good.
Old Sep 29, 2008 | 05:20 PM
jbrew's Avatar
Matts right , but you should post the codes to be sure. If you had Codes PO171,174, Yea head for that elbow. Your new O2's are reporting properly.
Elbow is here -
Scotty - That's my 98 5.4L. You need to post your engine size for accurate info.
Old Sep 30, 2008 | 12:07 AM
slomo_01's Avatar
Sorry yeah its the 5.4. I will check that elbow tomorrow. Thanks for the quick responses and all the help lets see if this is the problem. Can I just pick up a new elbow or is it a elbow and hose combo? Thanks Scotty
Old Sep 30, 2008 | 02:11 PM
Matts ford's Avatar
you can pick up just the elbow.
Old Sep 30, 2008 | 04:57 PM
jbrew's Avatar
Yea, you can -
But most want you to purchase the whole PCV assembly . I would get the whole thing on an older truck. Just because that plastic length of line between the elbows gets brittle over time and has been known to crack.
Complete system -
Old Sep 30, 2008 | 05:04 PM
jbrew's Avatar
Read post #6 here - (click on link below)
https://www.f150online.com/forums/en...ning-lean.html
