Changed plugs, did PCM relearn, engine stumbles.
I'm glad at least you have some codes now! XD When you let it coast down, it set the baseline for the pcm to diagnose missfire codes you got.
Did you wash (or otherwise wet) the engine recently?
No, I didn't wash the engine or get it wet since the plug change. I washed it about a week prior to the change.
I just finished pulling plug 2 and it looked fine and was gapped correctly. I applied grease to all plugs but the 2 under the computer. I figured I would do those tomorrow.
The engine still runs pretty rough but the CEL has not come back on since I had the codes errased.
I finally figured it out
After MUCH trouble I finally figured out what is going on. I pulled plugs 2 and 4 once again and noticed something different this time. Plug 2 looked okay, again. But, plug 4 looked very strange. At first I thought the electrode was pushed up into the porcelain but then I realized the porcelain was BROKEN and was sliding up and down in the tip. I double checked number 2 and it was exactly the same. No wonder number 2 LOOKED just fine before and explains why the misfire seemed random. This would also explain the P0300 code. I am going to call rockauto tomorrow and see if they can take care of me. I plan to ditch the champion plugs and install the motorcraft plugs.
Thanks to everyone for your help.
OK, I see several people referencing going back with Motorcraft plugs. Has Motorcraft come out with a 1-piece plug for our trucks now? If so, I need the part number. I have 8 Champion 1-piece plugs sitting in my garage waiting for install. So if there's a better option, I want to know it.
thanks
thanks
thanks
Thanks for the info. So is there any other option for a 1-piece plug besides the Champion? I only have 62K on my motor. I originally posted this link (episode 26) http://www.flatratetech.com/index.php?categoryid=4
a few days ago. I'm wondering if people are having trouble with their new 1-piece Champion spark plugs b/c they are not installing them correctly....peeps should be installing new plugs with Anti-sieze and the correct torque specs.
I removed my original plugs at 65,000 and went back with Motorcraft. The removed plugs looked like new on the tip.
One guy had the end of a Champion burn off and damaged a piston. Doubt that was caused by faulty installation. Several have had problems getting the proper gap.
So maybe, I should just leave it alone for now. My truck is still under the Ford Premium Care warranty till 100K miles. I only drive 12K miles a year. Maybe at 95K miles, I'll have the dealership change the plugs and let them deal with what happens. Please advise.
Thanks Bluejay432000.
Does that warranty cover all service? If it just covers repairs, I doubt very much it will cover a problem on the plug change, as it is usually considered a regular maintenance item.
I may be wrong on this, but I think one of the reasons that my plugs came out fairly easy at 65,500 miles is that I use gas with a good detergent. I try to get techron most of the time, which is Shell, Chevron, Texaco. I use Conoco or Phillips 66 and stay away from unbranded, Exxon and Mobil.
Changing the plugs yourself is not impossible it is just not very fun, if you break one or not.
I was very careful installing the Champion plugs and I still had problems. There are lots of variables that could have caused the Champions to break but I am certain it wasn't anything I did.
For me, I don't trust the Champion plugs now, that is why I am going back to the Motorcraft plugs. But in my case, I plan to trade this POS off once the new plugs arrive.
When I bought it, I planned to keep it for many years. When I bought it, I read as much as I could find and I thought I was getting a good truck. The problem is, this truck is costing me a ton in broken parts and maintenance. Plus, now I read the 04 has cam follower and phaser problems. Once the new plugs are in I am sure it will run much better. But in my case, this truck is a ticking time bomb that I need to get rid of.
Plus, I wouldn't mind changing the plugs every 12,000 miles if they didn't cost around $8.00 each.
