Help asap
Old Sep 27, 2008 | 06:22 PM
mav015's Avatar
Help asap
hey guys im tryin to change my oil i let the ford dealer do it before and now i can not get my oil filter off i have tried everything PLEASE HELP
Old Sep 27, 2008 | 06:24 PM
black hole's Avatar
Try pounding a long screw driver into the side of it and use it like a cheater bar.
Old Sep 27, 2008 | 06:26 PM
mav015's Avatar
thanks wat happens if the oil filter just tears?
Old Sep 27, 2008 | 06:27 PM
Keeks's Avatar
I would not recommend the screwdriver trick just yet. What have you tried that has not worked so far? Have you tried a filter wrench?
Old Sep 27, 2008 | 06:29 PM
xxs0ulxx's Avatar
okay so the filter wrench is going to squish the filter a lot. this is normal. just squish the crap outta that filer to torque it off..
Old Sep 27, 2008 | 06:35 PM
mav015's Avatar
thanks guys ill try to jsut squish it but my filter wrench wouldnt help at all but ill try
Old Sep 27, 2008 | 08:35 PM
ju015dd's Avatar
screwdriver works everytime like a charm. quick and easy, just make sure you have some old rags to wipe the mess up.
Old Sep 28, 2008 | 06:51 AM
Shorebird's Avatar
Try a strap wrench that has a shaft that is turned with a ratchet or breaker bar. They are available at most parts stores.
Old Sep 28, 2008 | 02:35 PM
Old Dogg™'s Avatar
Try it while the motor is cool also since heat makes things expand.
