Help with P0402
Old Sep 24, 2008 | 01:25 PM
ironman81's Avatar
Help with P0402
Here's the deal. I have changed the DPFE, EGR solenoid, EGR valve, throttle positioning sensor, and cleand my throttle body and I am stilll getting code P0402. What else might there be for me to do to fix this problem?
Old Sep 24, 2008 | 02:07 PM
Matts ford's Avatar
have you ever cleared the code after replacing everything?
Old Sep 24, 2008 | 02:10 PM
ironman81's Avatar
Yes
Old Sep 24, 2008 | 02:25 PM
Matts ford's Avatar
what year and motor?
Old Sep 24, 2008 | 02:27 PM
ironman81's Avatar
02' v8 4.6l
Old Sep 24, 2008 | 02:38 PM
Matts ford's Avatar
where did you get all the parts?
Old Sep 24, 2008 | 02:52 PM
ironman81's Avatar
At the ford dealership
Old Sep 24, 2008 | 02:54 PM
Matts ford's Avatar
i'd look for a vacuum leak. is it running a little rough or doing anything that its not suppose to do?
Old Sep 24, 2008 | 02:56 PM
ironman81's Avatar
It is a little sluggish. I have checked all the lines for cracks or any leaks. Maybe I will just replace all the lines and see what happens.
Old Sep 24, 2008 | 08:18 PM
jbrew's Avatar
If it's a new valve - Suck test it. Make sure it's operational.
Leaks will produce that code like Matt suggests.
Heres where she may leak , the EGR (valve to plenum) uses an aluminum gasket. If used more than once, you need a very very thin coat of Permatex on both sides. Only IF it is indeed Aluminum. RTV Type -Black or Red will work / Coppers best.
The two rubber DPFE hoses can leak and the EGR pipe itself may leak.
Good idea to check all that stuff first.
Old Sep 24, 2008 | 09:18 PM
chiefFX4's Avatar
was thinking something different...
